Kenmore (Whirlpool) 110.82374110
Washer Thinks its Done
4 replies to this topic
#1 Milanomike
Milanomike
    Ikkō-ikki
  • 36 posts
Posted 06 September 2011 - 08:01 PM
My old Kenmore (Whirlpool) washer seems to work fine, but occasionally it seems to think the cycle is complete. It will stop, but it has not pumped out the water or completed the cycle. I'm guessing the timer is calling it a day, anything else to check before I pull this thing apart. Not sure it's worth spending 100+ on this machine if this is the case as it's certainly 25 yrs old, but I figure I at least owe it a look before I make a decision. Thanks for any help.
Mike
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 06 September 2011 - 08:46 PM
Could be a failing lidswitch
http://www.repaircli...er=110.82374110
When the timers failed on those old Belt Drives, you could usually verify the fault by wiggling timer shaft while running and see it cut out
#3 Milanomike
Milanomike
    Ikkō-ikki
  • 36 posts
Posted 07 September 2011 - 09:18 PM
I have fiddled with the lid switch and thought it was OK, probably worth another look. Great tip on the timer shaft. Thx, will report back.
Mike
#4 Milanomike
Milanomike
    Ikkō-ikki
  • 36 posts
Posted 12 September 2011 - 08:22 AM
OK, switch seems good, solid click each time it is pushed, wiggling timer shaft does not start or stop machine. Currently machine stopped in mid cycle and will not run or drain tub, it simply makes a noise, I thought the belt might be slipping, but the noise is not the motor spinning. Some kind of electical noise, like a relay maybe. Any thoughts appreciated.
Mike
#5 kdog
    RoughShod
  • 7,474 posts
Posted 12 September 2011 - 01:17 PM
Sounds like the pump mignt be seizing up on you - when it quits like this, unplug machine and move belt by hand - watch pump pulley to see if it is moving with the belt, if not, it's new pump time ....
