JennAir side by side. Trickle of water flow and hollow ice cubes. Related?
4 replies to this topic
#1 lfreng
lfreng
  • 7 posts
Posted 07 September 2011 - 11:25 AM
Could these two conditions be related? I tried replacing the water filter and that helped a bit for a while. It will literally take me a minute + to get 8 oz of water out of this thing. The water filter doesnt seem to be the issue as it didnt really improve things. Might of shaved 10 seconds of the fill rate. I tried finding a search function on this forum to see what else has been posted on this topic but dont see that function. Any help would be appreciated.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 September 2011 - 11:36 AM
Are you using any external Water Filters or an RO (reverse osmosis) water system ?
#3 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,903 posts
  • Flavorite Brew:Killians Red
Posted 07 September 2011 - 11:37 AM
How strong is the pressure on the supply line feeding the fridge?
was a pierce-type saddle valve used?
remove the line from the rear and let it flow into a bucket...is the stream strong and robust?
if not, there is your issue...
#4 lfreng
lfreng
  • 7 posts
Posted 07 September 2011 - 11:43 AM
No other water filters used. gate valve is used off cold supply at sink. Normal pressure is present. Maybe I will just bypass it. I dont really care if the water is filtered or not. Wife probably will though...
#5 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 820 posts
Posted 07 September 2011 - 04:46 PM
If you have normal pressure going to the water valves and weak pressure coming out then your valves might be gook'd up. What's your water source?
