FAQs | Store | Memberships | Repair Videos | Boot Camp | Newsletter | Beer Fund | Contact
Maytag DG 303
10 replies to this topic
#1 Cant Dry in MN
Cant Dry in MN
  • 6 posts
  • Flavorite Brew:Linnies
Posted 07 September 2011 - 01:37 PM
Ok Guys and or Gals...
Got a Maytag DG 303 dryer and its not working so good...
Replaced the Gas Valve relays, yet, the Ignitor Glows, The Gas Fires.. Pretty Blue and Orange flame are Present... For just a short time...
Then Poof, it goes out, Not to Be Seen again unless I stop the Process and Start it over again...
What do I need to replace now?
Cant Dry in MN
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 September 2011 - 01:55 PM
... Ignitor Glows, The Gas Fires.. Pretty Blue and Orange flame are Present... ..
... Then Poof, it goes out,
was that the original symptom ?
... Dryer must be fully assembled for correct air-flow ... :whistling:
#3 Cant Dry in MN
Cant Dry in MN
  • 6 posts
Posted 07 September 2011 - 04:00 PM
Original Problem was that the Gas would ignite, but go out after 20 or 30 secs then not reignite...
and its fully assembled with all parts in their proper positions..
    Shōgun
  • 28,708 posts
Posted 07 September 2011 - 04:11 PM
Run it again but with the vent completely disconnected from the back of the dryer.
#5 Cant Dry in MN
Cant Dry in MN
  • 6 posts
Posted 07 September 2011 - 04:37 PM
Started cycle with Vent hose On ignition and fire for 12 secs
Started cycle with Vent hose Off, Ignition and fire for 43 secs
#6 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 788 posts
Posted 07 September 2011 - 04:39 PM
43 seconds might be enough time for the dryer to get up to temp when empty. Does it cycle back on?
    Shōgun
  • 28,708 posts
Getting warmer! Check that blower wheel, you might find it slopped out on the motor shaft which will impair air flow. Do you remember hearing a rumbling from inside the dryer when it started up and stopped?
#8 Cant Dry in MN
Cant Dry in MN
  • 6 posts
Posted 07 September 2011 - 05:05 PM
Did not cycle back on.... and... there is a rumbling of sorts I guess yeah...
#9 Cant Dry in MN
Cant Dry in MN
  • 6 posts
Posted 07 September 2011 - 07:12 PM
Discovered after taking off the front cover for the blower assembly that the Blower Fan is in fact wobbling on the motor shaft
and is looking as if its been vibrating consistently for awhile...
So looks like this could be the culprit...
    Shōgun
  • 28,708 posts
Posted 07 September 2011 - 07:25 PM
Your blower wheel, sir ==> http://www.repaircli...delNumber=DG303
#11 Cant Dry in MN
Cant Dry in MN
  • 6 posts
Posted 07 September 2011 - 07:36 PM
Thank You Very Much Sir
