Strange Kenmore Dishwasher crash 665.17039401
4 replies to this topic
#1 bonsaijim
bonsaijim
  • 3 posts
  • Flavorite Brew:shiner bock
Posted 07 September 2011 - 09:37 PM
When you hit start, the normal wash and heated dry will light up but nothing happens. They will turn off if you press them. Hitting start will stil not do anything. If you hit Cancel all lights will go out.
If you hit the heated dry - normal heated dry normal to try and reset all lights flash.
It will not run but the drain button works.
Last night it did this and fiddling with the butttons got it to run. Today- nada...
Ideas?
Thanks in advance!
#2 bonsaijim
bonsaijim
  • 3 posts
Posted 07 September 2011 - 10:09 PM
Also, according to my son it would revert to these settings when he was using over the last few weeks and he had to mess with ita few times to get it to the settings he wanted and then start.
#3 bonsaijim
bonsaijim
  • 3 posts
Posted 08 September 2011 - 09:55 PM
Nothing?
#4 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,201 posts
Posted 09 September 2011 - 07:14 AM
Sounds like the typical malfunctioning touchpad. The main control boards rarely fail in these but all the time see bad membrane touchpads in all brands and models.
William Burk (Willie)
Eureka, CA 95501
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 09 September 2011 - 07:51 AM
if needed:
http://www.repaircli...R=154&N=1066180
http://www.repaircli...R=154&N=1066181
