Kenmore Mod # 110.62712101 Dryer heating element
heating element
13 replies to this topic
#1 tick
tick
  • 16 posts
Posted 08 September 2011 - 09:53 AM
Gurus...will someone please send me a diagram on how to change out the heating element on my Kenmore electric dryer? I am sure it is not too difficult but need some expert help.
thank you!
#2 RegUS_PatOff
  • 30,701 posts
Posted 08 September 2011 - 11:01 AM
http://www.repaircli...sp?R=154&N=2438
then click on the Part Replacement TAB above the video
#3 tick
tick
  • 16 posts
Posted 08 September 2011 - 11:21 AM
Thank you! very helpful I will post back once the repair is complete & tell you how it went
#4 tick
tick
  • 16 posts
Posted 19 September 2011 - 02:12 PM
I got the heating element out & tested continuity. It said 9.6 on the meter so I assume this means it is still good?? What would be my next step? The dryer vent is fine. Basically it is taking 2-3 cycles to dry clothes. Could someone help with Thermostat testing or ideas?
thanks!
#5 RegUS_PatOff
  • 30,701 posts
Posted 19 September 2011 - 02:16 PM
try a load with the Vent disconnected ...
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
#6 tick
tick
  • 16 posts
Posted 19 September 2011 - 02:44 PM
did that a while back can't quite remember the temp but it wasn't too hot warm mostly
the vents are all fine
next?
#7 RegUS_PatOff
  • 30,701 posts
Posted 19 September 2011 - 03:30 PM
If the Vent is OK and it's warm, but not reaching temperature,
and the air-flow is OK
then that would indicate the Operating Thermostat is bad.
http://www.repaircli...sp?R=154&N=2893
#8 tick
tick
  • 16 posts
Posted 19 September 2011 - 04:33 PM
ok...we are getting somewhere now! is there a test I can do on the ole one?
#9 RegUS_PatOff
  • 30,701 posts
Posted 19 September 2011 - 05:49 PM
if you could somehow monitor it with a voltmeter while the Dryer is running ...
to see if that's what's "opening" too soon
  • 24,720 posts
Posted 20 September 2011 - 07:41 AM
You can also use an electric skillet and see if the contacts open when the thermostat reaches 165F or so.
#11 tick
tick
  • 16 posts
Posted 20 September 2011 - 09:02 AM
Learn me something guru! the high limit thermostat would seem to be working if the heating element is heating up but not reaching temp for a period of time??
the cycling (operating) thermostat tells the element how long to stay heated then cool then heated again? If it is bad then it is not staying heated long enough in cycles?
ok....moving on....how do I test with the electric skillet? how would I know when the contacts opened up?
#12 Samurai Appliance Repair Man
  • 24,720 posts
Posted 20 September 2011 - 09:08 AM
You're a Merit Apprentice Appliantologist so presumably you know how to use a multi meter.
#13 tick
tick
  • 16 posts
Posted 20 September 2011 - 09:30 AM
somewhat...just learning really
#14 tick
tick
  • 16 posts
Posted 20 September 2011 - 10:22 AM
It sounds like a have a bad operating thermostat as stated above. Youtube/Google taught me how to test with my multimeter & use the electric skillet trick. I appreciate the help
I'll report back
