Change from Gas to Propane on Range Electrolux EW30DS65GS
flame gas propane electrolux stove
8 replies to this topic
#1 GTSECC
GTSECC
  • 5 posts
  • Flavorite Brew:Coca-Cola
Posted 09 September 2011 - 09:33 AM
Does this look like the burners need to be adjusted?
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
  • Flavorite Brew:Killians Red
Posted 09 September 2011 - 10:06 AM
If you changed from natural gas to LPG ...yes this needs to be converted.
call electrolux...some of these units were designated non-convertible...must come from the factory preset for the proper gas :o
#3 GTSECC
GTSECC
  • 5 posts
Posted 09 September 2011 - 10:23 AM
Well, I implied that I changed, but really, this is a new install.
Before I go about fixing it, I am simply trying to determine if it is broken.
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
Posted 09 September 2011 - 10:55 AM
Ok let's start over...what type of gas system is this unit on? Nat or LP?
what gas was the stove set for from the factory? (Usually Nat unless otherwise noted)
Just judging by the video...I would guess you are on a LP system but the stove is set for Nat. Gas...
#5 GTSECC
GTSECC
  • 5 posts
Posted 09 September 2011 - 11:55 AM
My house is on LP.
The contractor installed the stove.
I have no way of knowing if they did anthing or not as I have found him to have been dishonest about some things.
I posted the video in the hopes that someone familliar with what it should look like could say that it does or does not look correct.
  • 24,296 posts
Posted 09 September 2011 - 12:58 PM
That burner is not operating correctly. And since this is happening to all the burners, and given that you're running LPG, it's a slam dunk that the stove burners were not converted to burn LPG. Contractors are famous for screwing that up.
Next step is to locate the conversion kit for your range, assuming one exists. I'll do some poking around and see what I can find.
#7 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
Posted 09 September 2011 - 01:21 PM
That would be me saying it does not look correct...
maybe the boss can let ya know whether or not this unit can be converted...
#8 RegUS_PatOff
  • 30,261 posts
Posted 09 September 2011 - 07:35 PM
EW30DS65GS
depending opn the missing last digit of your model number,
this may be your
LP Instruction Sheet
http://www.repaircli...R=154&N=1793695
and LP Conversion Kit
http://www.repaircli...R=154&N=1793431
#9 jambatt
jambatt
    Senpai
  • Scholar of Appliantology
  • PipPipPipPip
  • 792 posts
Posted 09 September 2011 - 09:20 PM
Don't forget about the oven burner..........it has to be converted also.
Don't take life too seriously, none of us get out alive !
