  • Announcements
MikeCaldwell
Frigidaire E47 problem
6 posts in this topic
I am getting an E47 error code and have pulled the latch assembly out, Where do I check it for ohms?
I feel a haiku coming on. Wait for it... Wait for it...
Friggidaire washer
E47, no spin.
Replace the lid switch
Thanks for the instructions to remove the latch but I already did that. what I need to know is where exactly should I be getting the ohms reading from on the latch if that matters at all. I have the meter to test it with just want to make sure I am testing at the proper spot/terminals. I have put the meter on it and assuming it is the proper spot I get a reading of 1329 ohms.
Thanks, Mke
Any reading you get will be misleading or a meaningless waste of time. But, if you have time to kill, the see the wiring diagram in the tech sheet.
Or just replace the door latch and go on with life.
Part link to the door switch assembly ==> http://www.repairclinic.com/PartDetail/Door-Switch/131763202/1531974
Thank you for your insight, That is a much better option than the board as far as my wallet is concerned!
Door latch received & replaced today & all is back to normal again!
I shall go on with life now!
Thank you!
