Power surge Frigidaire FAFW3511KWO front load washer
#1
Posted 10 September 2011 - 06:16 AM
Question is - where do I start looking? Of course there are loads of susceptible electronics in there - but where to start?
#2
Posted 10 September 2011 - 07:12 AM
maybe Home Depot... where do I start looking?
the main Control Board may be bad, but hopefully not the Motor Controller ...
Take a look, seems there'll be visual evidence ...
#3
Posted 12 September 2011 - 07:59 AM
And is there a risk of burning out the new control board when I install it and then try to start the machine if something downstream is bad?
Thanks. I know this calls for speculation but I will take your expert opinion gladly.
#4
Posted 13 September 2011 - 05:31 AM
Eureka, CA 95501
#5
Posted 13 September 2011 - 07:43 AM
OK - I see a burn mark on the control board right where the 120V line plugs in.
Pictures, pictures!
#6
Posted 13 September 2011 - 08:52 AM
http://www.repaircli...irHelpVideoTabs
It was right where the green plug with black and white wires enter (green plug).
#7
Posted 25 September 2011 - 06:01 PM
1. main control board ($130)
2. user interface board ($110)
3. pressure switch / sensor ($45) - plugs into the control board
The surge was caused by an open neutral - an underground cable let go. Thus I got 240v on half of the panel - including the washer.
Now my washer plugs into a high quality surge supressor which in turn plugs into a GFCI. I also have a whole house surge protector (which fried). The surge knocked out 6 GFCIs and 3 high quality point-of-use surge supressors. These items saved all my other electronics so I feel a little better my washer is now protected also.
Tip of the week: BE SURE YOUR DRAIN HOSE DOES NOT WORK ITS WAY LOOSE as you slide the washer in / out many times making these step-wise repairs. It was wired down but not enough to handle so many in / outs. My house survived Hurricane Irene but not a loose drain hose!
IMG_3865.jpg 72.76KB
7 downloads
#8
Posted 25 September 2011 - 06:25 PM
#9
Posted 25 September 2011 - 06:48 PM
Nice pics and Thanks for that follow-up; I find that proper use of the candycane on the drainhose pervents "accidental fallout"
http://www.repaircli...ber=FAFW3511KW0
Also tagged with one or more of these keywords: Power surge
Appliantology Appliance Repair Forums →
The Kitchen Appliance Repair Forum →
Dacor Dbl. Oven CPTS227 won't come on after power surgeStarted by Auggie, 16 Nov 2012 |
Fisher & Paykel E533BRX fridge ? damaged by power surgeStarted by DocKent, 04 Nov 2011 |
