Jenn Air JDS 9860BDB control panel part #?
7 replies to this topic
#1 MNAGLE
MNAGLE
  • 4 posts
Posted 12 September 2011 - 11:22 PM
This is a dual fuel slide in range. When I power the thing off and on I get EE-214 M-214 showing on the front. Number pad works, timer works, oven and fan won't come on and I can't set the clock.
All my research says I need to replace the electronic control (I did research this as much as I could before posting the question), but I'm struggling to figure out which part number I need for this model.
Also, some of the stuff I've read says the number pad and electronic control on a lot of these are two separate parts, both expensive, and it's hard to tell which is bad. I'm thinking the number pad must be OK since it works (takes inputs) properly but the electronic controls have failed.
Any words of wisdom are more than welcome.
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 12 September 2011 - 11:50 PM
Not finding those error codes in the literature, could be displaying software id - this looks like the control:
http://www.repaircli...7P23460/1603271
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 13 September 2011 - 03:31 AM
that looks like the Electric 8507P234−60
He needs the Gas version 8507P231−60
http://www.repaircli...R=154&N=1617409
#4 MNAGLE
MNAGLE
  • 4 posts
Posted 16 September 2011 - 05:32 PM
So where I have an electric oven and a gas cooktop, which one do I need?
#5 RegUS_PatOff
  • 33,588 posts
Posted 16 September 2011 - 06:39 PM
:kopkrab:
looks like you'll still need the "Gas" version 8507P231−60
Repair Part List - W10316980.pdf Electric
Repair Part List - W10317524.pdf Dual Fuel
#6 MNAGLE
MNAGLE
  • 4 posts
Posted 27 September 2011 - 11:00 PM
OK, I changed the control and the symptoms didn't change. I'm guessing that means I've got a bad number pad? Whats the part # on that?
#7 RegUS_PatOff
  • 33,588 posts
Posted 27 September 2011 - 11:43 PM
.. I get EE-214 M-214 showing on the front.... and I can't set the clock
have you recently used Self-Clean ? :nono:
http://www.repaircli...R=154&N=1482202
#8 MNAGLE
MNAGLE
  • 4 posts
Posted 28 September 2011 - 12:08 AM
Nope, no self clean. I take it that's a bad thing to do?
