KitchenAid Combo Microwave and Oven KEMC377KLBO
GreenestOne
  • Replies 6
  • GreenestOne
  • kdog
  • rhellner
can you check that model number again ?
The model number is: KEMC377KBLO (parts can be seen on the Repair Clinic site with this number) Thanks.
K/A B/I Oven/Micro Combo manual P/M'd
Thanks for the link, but what came up was a Whirlpool page which requires username and password to access it, and no apparent way to sign up.
that's a little better
KEMC377KBL0
Tech Sheet - 4452295.pdf
link PM'd
  • 10 months later...
