Panasonic Microwave NN-SD277W
H95 Error
1 reply to this topic
#1 Sonic
Sonic
    Sōhei
  • Chief Appliantologist
  • 133 posts
  • Flavorite Brew:Alexander Kieths
Posted 14 September 2011 - 10:56 PM
I am working on a Panasonic microwave NN-SD277WW and was able to get into a test mode by pressing Clock, Timer, Start, Power with the Hi voltage leads disconnected from the inverter. I programmed one minute and and started the microwave. It ran for 3 seconds then displayed H95. I found this test at http://www.electroni...1bf-t62888.html On answer I found on the net said that H95 meant the inverter was shorted. Can someone confirm this?
#2 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 16 September 2011 - 08:01 PM
Ensure your filament leads on the magnatron aren't open (open = bad)
need to verify that your getting 120V to the inverter (if not = bad board)
the 2 signal wires to the inverter should be showing 3VAC from the board (if not = bad board)
If the above all check good then you have a bad inverter.
How to troubleshoot a Panasonic microwave oven with an H95 error code
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 16 September 2011 - 08:06 PM
Master appl.tech offers these tips:
If the above all check good then you have a bad...
Read Full Entry →
