Frigidaire LGHS2665KF0 / ice on evaporator fan
freezer evaporator fan ice frigidaire
3 replies to this topic
#1 bridgstar
bridgstar
  • 2 posts
  • Flavorite Brew:Heineken
Posted 18 September 2011 - 03:57 PM
Hi everyone! I'm looking for some help with the freezer in my not-very-old Frigidaire side-by-side refrigerator. Every few weeks for the past six months or so, enough ice builds up on the evaporator fan to cause a terrible grinding noise. I've gotten pretty good at taking the freezer apart to clear the ice off the fan... but I'm getting tired of this routine and hope to fix the problem instead of continually managing the symptoms.
At first we thought the ice bucket might be getting too full, sending excess water/ice into the back panel. But even when we kept the ice bucket virtually empty, ice still built up on the evaporator fan.
Appreciate any suggestions anyone can provide!
#2 RegUS_PatOff
  • 30,269 posts
Posted 18 September 2011 - 05:00 PM
Is the entire Evaporator Coils frosted evenly, or only partially ?
May need to post a picture somewhere, then post the link here..
Sounds like a Defrost problem (or worse)
If you could use an OHM meter to test the Defrost Heater
#3 bridgstar
bridgstar
  • 2 posts
Posted 18 September 2011 - 05:05 PM
The evaporator coils do not seem to be frosted evenly. I'll take a picture next time I take it apart...
#4 certified tech group 51
  • 1,987 posts
Posted 29 September 2011 - 11:02 AM
Do not know if your problem has been fixed, I ran across a few of these unit with a chunk of ice forming on the rear wall of the freezer near the evap motor...kinda off to the left side.....If you look at the I/M fill tube, half of the fill tube slot is behind the rear panel.......I cover the slot from the panel towards the rear.......The slot should be open from the panel forwards........Discovered that during I/M fill cycle, the water was splashing out of the back half of the slot and running down the back wall and the freezing into a chunk of ice that grows towards the motor....I used HVAC foil tape, the H.D. type. keep us posted......
Also tagged with one or more of these keywords: freezer, evaporator fan, ice, frigidaire
0 members, 1 guests, 0 anonymous users
