GE double electric oven JTP27BOA5BB temperature issue
GE oven
2 replies to this topic
#1 Skippy424242
Skippy424242
  • 2 posts
Posted 20 September 2011 - 05:56 PM
The lower oven on my GE double electric oven JTP27BOA5BB doesn't heat up properly. The lower element doesn't get hot at all, whether I set the temp to 350 or broil. The top element heats up at either temperature. That doesn't seem right to me, because I thought the top element was for broil only. I pulled the lower element and checked the continuity. It seems to be fine (reads about 20 ohms). Can someone recommend a next step? The lower oven is controlled by a single temperature dial; the upper oven has a full digital panel.
#2 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 20 September 2011 - 07:48 PM
you most likely have a bad thermostat. would you by chance have a copy of the wiring
diagram?
www.eliteapplianceservice.org
#3 Skippy424242
Skippy424242
  • 2 posts
Posted 20 September 2011 - 08:40 PM
I don't have a copy of the wiring diagram. I have looked online and haven't found it yet.
I am confused about which element is supposed to do what?
Also tagged with one or more of these keywords: GE oven
