GE Control Board-What Happens If I Dont Cut Thermistor Wire?
5 replies to this topic
#1 deezus
deezus
    Kohai
  • Chief Appliantologist
  • 358 posts
Posted 21 September 2011 - 10:40 AM
What happens if the Pin 2 of the J1 connector isnt cut when installing a mainboard on a listed encoder model? I have a refrigerator where another guy installed the mainboard and didnt cut the wire? The damper is acting up and so is the evap fan. I looked at the old board and saw that it did have a burn mark on it but the resistors at the eveap fan were good.
Thanks!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 21 September 2011 - 11:01 AM
I don't know exactly, but it work work correctly.
Why not just cut it ?
(if the Fridge has the correct serial number prefix)
#3 deezus
deezus
    Kohai
  • 358 posts
Posted 21 September 2011 - 12:41 PM
I am going to, you see, the mainboard was installed by another company not me. I was just curious because,damper is wide open freezer is cold and making ice but refer is at 55 degrees. I will cut it and get back to you.
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,893 posts
  • Flavorite Brew:Killians Red
Posted 21 September 2011 - 12:45 PM
Evaporator fan running?
defrost system functioning properly?
don't assume because the" other guys failed to cut the jumper that this is your only problem...
#5 deezus
deezus
    Kohai
  • 358 posts
Posted 21 September 2011 - 04:14 PM
Yes/sometimes.
Yes
The freezer was cold making ice just no air flow from freezer to fridge.
#6 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,893 posts
Posted 21 September 2011 - 06:16 PM
Well if the freezer is cold enuff, the fan is working, the coil is clear, and the damper is open...
nothing left but return air and im sure you checked those when you had the coil exposed...
thermistors?
