  • Announcements
      ***CLICK HERE AND READ THIS PRIOR TO STARTING A NEW TOPIC***   05/02/2016
tick
Kenmore Elec Dryer 110.62712101 No heat/timer not moving
4 posts in this topic
I took the vent off the back to see if the vent to the roof was restricting airflow (had warm air but took long time to dry). I set on High with a load in, watched the heating element heat up, ran good for about 20 minutes, dryer felt pretty dang hot, then went cold. No more heat & the cycle timer did not move from that point on.
Took heating element, HL thermo, internal bias thermo, fuse, & the other thermo attached to the element to the shop & all tested good. Checked my breakers, good but turned on/off just to be sure. Checked lint trap...clean.
Put all parts back on, but still no heat & the cycle timer is not counting down.
Any Ideas??
thanks
And you ran this entire subsequent test with the vent removed?
Was this test run with the dryer in timed dry mode or auto dry?
yes with vent removed just a pair of panty hose over the exhaust
timed dry mode
