Whirlpool duet washer WFW9750WW01
whirlpool duet not working
5 replies to this topic
#1 tars
tars
    Ikkō-ikki
  • Apprentice
  • 31 posts
Posted 22 September 2011 - 03:28 PM
This washer has water heavy clothes after cycle is finished.
First I cleaned out the drain pump ( bobby pin was found lodged in impeller) .
Then after that ended up replacing drain pump altogether.
Still clothes are not spun out after cycle is finished.
No error codes. When unit is tested for drain/spin it works fine.
Don't know what to check for at this point.
Any ideas?
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,912 posts
Posted 22 September 2011 - 06:52 PM
This needs to be moved to the laundry topics.
Scott Wolf
  • 24,268 posts
Posted 22 September 2011 - 07:08 PM
Good catch, Scott! Topic moved.
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,912 posts
Posted 22 September 2011 - 07:16 PM
I would suspect the water inlet valve may not be closing. The water inlet valves on these Duets seem to have a high failure rate.
Scott Wolf
#5 Tronicsmasta
Tronicsmasta
    Kohai
  • 493 posts
Posted 22 September 2011 - 07:28 PM
We have gotten tons of complains about it. The recommended fix by Whirlpool is replace the MCU if everything else checks ok.
Check These:
Drain hose not siphoning back into washer,
Inlet Valve for dripping overnight,
Shocks,
Springs,
Level Unit,
Sorting of Clothing (bad sorting = jeans with t-shirts),
Load Size (About 2/3 full max),
HE detergent only (Tide, Gain, Cheer)
It is never a bad thing to leave it to the professionals. Inexperience can lead to more damage or risk of injury. You can always call A&E Factory Service (1-800-905-9505), Sears(1-800-469-4663), or local service man you can trust (servicemagic.com).
#6 tars
tars
    Ikkō-ikki
  • Apprentice
  • 31 posts
Posted 22 September 2011 - 10:13 PM
thx guys. sorry about posting in the kitchen forum.
