Whirlpool LEQ9858LW0 Dryer lint chute seal replacement?
#1
Posted 23 September 2011 - 09:18 AM
#2
Posted 23 September 2011 - 12:44 PM
#3
Posted 23 September 2011 - 04:26 PM
#4
Posted 23 September 2011 - 05:03 PM
#5
Posted 23 September 2011 - 09:48 PM
#6
Posted 23 September 2011 - 09:51 PM
#7
Posted 24 September 2011 - 10:43 AM
...i will make another post. Thanks for taking the time to respond to my post.
If you require further advice, simply post again in this same topic as background info follows the appliance
Wisdom! Let us attend!
#8
Posted 25 September 2011 - 03:58 PM
NEW DEVELOPMENT! Serious help needed here! As stated a couple posts ago I have been battling long drying times with my dryer and have done a few things to try and figure the problem out and am in the middle of troubleshooting. Entire chain of exhaust and lint chute are completely clean from inside the dryer to the exit outside my house and have put a new heating coil in. I have used the dryer a few times since doing this but still troubleshooting. Yesterday I ran a load of laundry but my results are still inconclusive HOWEVER today we were doing a load of laundry and when we opened the dryer to put the clothes in heat was radiating out of the dryer big time and it hadn't been used for 24 hours. I put my hand up next to the heat intake inside the drum and it's hotter than hell. It's like the coils are on and never shut off! So this is a major turn of events, I fear I'm going to have a fire. Any help would be appreciated!! Thanks!
#9
Posted 25 September 2011 - 04:02 PM
#10
Posted 25 September 2011 - 04:10 PM
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
#11
Posted 25 September 2011 - 04:15 PM
#12
Posted 25 September 2011 - 04:27 PM
1) Vent is rigid metal. I fully cleaned it out from end to end.
2) Short, flexible metal transition vent. NOT crimped at all, NO screws. I fully cleaned it out from end to end.
Right now the airflow at the vent exit at the back of the house is excellent. I still need to disconnect the vent from the dryer and check the airflow there. However, since I see excellent airflow from the vent exiting the house and since I cleaned the living hell out of the vent from the lint chute all the way to the exit that seems moot at this point. Next step is to measure the temperature of the heat, just haven;t done it yet. Again, still confused at the why the heat coils came on when my wife turned the dial to Auto dry and we hadn't yet started the dyer. Thanks!
#13
Posted 25 September 2011 - 04:31 PM
#14
Become an Apprentice Appliantologist and Enjoy Special Perks
Heater Element shouldn't be powered without Drum Motor turning
unless the Element is partially shorted to ground
(or the Motor Centrifugal Switch is shorted)
If so, the Element will over-heat and (should) blow one of the Thermal devices
Edited by RegUS_PatOff, 25 September 2011 - 05:07 PM.
#15
Posted 25 September 2011 - 04:36 PM
#16
Posted 25 September 2011 - 05:08 PM
also, edited my previous post to "shouldn't" be powered
#17
Posted 25 September 2011 - 05:21 PM
#18
Posted 25 September 2011 - 05:30 PM
#19
Posted 25 September 2011 - 05:55 PM
- Cycle Thermostat
- Thermal Cut-Off
- High Limit Thermostat
You guys are experts, any of those likely not the culprit? Can each of these be tested? Sorry, total newb, if they can be tested, how so? I can get an ohm meter tomorrow if that would work.
#20
Posted 25 September 2011 - 06:21 PM
don't have my meter with me.
Pretty much a "must-have" when checking such devices. First up alway's disconnect vent for a cycle to see if issue goes away, no matter how good you think the vent looks - be sure to open up a nearby window when doing so to allow air exchange. This takes the Vent out of the equation and provides access to output heat. Remove rear panel from Dryer and (Unplug) and hook up meter leads to element terminals and place the meter where you can read it and leave it connected while you test various things (selecting cycle, pushing start button etc) there is then no question whether the element should be getting hot then. If your element gets power with the Dryer off or not running you should not leave the unit plugged in (turn off breaker)
Also tagged with one or more of these keywords: dryer, seal, lint, chute
