Fridge not cooling, Model KSRA25ILWH02
4 replies to this topic
#1 NateP
NateP
  • 1 posts
  • Flavorite Brew:Manny's brewed in Seattle
Posted 23 September 2011 - 06:05 PM
Power is on, freezer fan runs, but no cooling. Circuit panel working. Cleaned the coils which were filthy, and checked the compressor relay which appears good. Still no cooling.
It tries to come on, then clicks off in about 2 minutes. Next step? I guess I can try to verify power @ the compressor, but if it's clicking on/off, I assume it's receiving power.
#2 kdog
    RoughShod
  • 7,428 posts
Posted 23 September 2011 - 06:22 PM
That's what happens when the relay is NOT good
http://www.repaircli...er=KSRA25ILWH01
#3 RegUS_PatOff
  • 30,283 posts
Posted 23 September 2011 - 09:49 PM
... then clicks off in about 2 minutes. .
... although, if it's running for that long, the Relay may be OK, and the Compressor may be bad.
#4 kdog
    RoughShod
  • 7,428 posts
Posted 23 September 2011 - 09:54 PM
Indeedly Dudely ! Ye shall commence with ohmeter test of compressor pins and each to it's Welded Copper Lines
Look Here: http://fixitnow.com/...clicking-noise/
And Here: http://fixitnow.com/...t-run-and-main/
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 1,751 posts
Posted 24 September 2011 - 08:45 AM
You can always give the relay the ol' shake test....ie take it off, shake it and if it rattles, replace it.
