Whirlpool washer model LSC8244BQ0 wont agitate, spin or drain
1 reply to this topic
#1 Meekum
Meekum
  • 1 posts
Posted 24 September 2011 - 05:53 AM
Hey guys, I'm pretty new to this, and I was wondering if someone could help.
A couple of weeks ago the washer stoppe agitating, spinning and draining. When it gets to the spin cycle the motor hums for a little bit then shuts off
I took the entire thing apart and began to look at everything. Here is what i've tried recently.
Put a jumper into the close button. Still did not work
Looked into the pump. Nothing out of the ordinary.
Bought a new motor thinking that it was just old and worn out and just didn't have the torque needed to go into spin. Motor still hums on spin cycle after it attempts to spin the bin.
I can spin the motor while its in the tranny a couple of times and after trying about 5 times I can put it on the spin cycle and the bin will spin like its on spin cycle without slowing (I could do this with the old motor as well). However it just stay this way and the humming will eventually come back. I cannot spin the bin by spinning the motor unless using channel locks (if that is a problem).
The washer spin bin is hard to turn and makes scratching sounds when it does. Could this be why the motor is humming?
Please help, I'm completely lost at this point, im sorry for posting so much, but i've tried alot of experiments to see whats going on, thought they might help diagnosis.
    Shōgun
  • Master Samurai Tech
  • 30,207 posts
Posted 24 September 2011 - 10:53 AM
Unclip the pump from the motor and tie it back to the frame leg. Run the washer again and see how it runs with the pump out of the equation.
If that's good, remove the motor and inspect the coupler.
