gsherrill
GE Spectra Range w/ F0
10 posts in this topic
The subject is a GE Spectra JB960 convection range purchased 3/2001. (Model # JB960AB4AA). Current state is a flashing clock that continues to keep time on the right of the display, with a solid "F0" on the left half of the display. All of the buttons on the control panel are inactive. Removing power from the unit for five minutes, then restoring power, did not change the situation. (Tried that 2x.) Upon power-up, the display returns to the state described above and the unit beeps every second for a few minutes, then stops beeping. All burners on the cooktop continue to operate correctly.
No aberant behavior was observed before this evening. While cooking dinner this evening, though, an attempt to pre-heat the oven to 450 (in regular bake mode) seemed to stop at 417. Upon pressing stop, then using convection bake to preheat to 450, the thermostat did record the temperature going to 450 with the appropriate "beep" to indicate the set point was reached. Pressed stop at that point, then pressed bake, set 450, pressed start, and the unit correctly indicated 450. The range remained in bake at 450 for about 20 minutes, at which point it was turned off. About an hour and a half later, I heard the stove start beeping, and upon inspection noticed the display in the state described above.
I understand that F0 indicates a thermistor control failure, and want to be sure that my only recourse is to replace the ERC. From posts on your site it appears that touchpad issues would usually result in an F1, at least at some point. I will check the thermistor this evening to be sure it is reading about 1 k ohm at room temp. Do I troubleshoot an F0 (with no other fault codes) the same as an F1 and remove the touch pad connection, etc.? Thanks for your service!!
Depends on what style range, here are your options:
F0 or F1 Failed transistor in control.
1.  If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad.
__________________________________________________________________
GE
XL44 Self Clean Oven Fault Codes
Failure Code Condition Check/Repair
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs.
3. If code recurs, problem is in the control. Replace Control.
4. If code does not recur, problem is with the Key Panel.
___________________________________________________________________
GE
"New '99" Range/Stove/Oven Fault Codes
FFF Control Error.
1.  Failed EEPROM Replace Control.
F0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch.
1.  Check Electronic Range Control (ERC).
GE
F0 and F1 Failed Thermistor Control
1.  Replace Electronic Range Control (ERC).
Based on the model number and all literature I have on it, it's neither the "XL44" nor the "New 99" type, so that leaves me with the generic fault code, which simply says "replace ERC" for both F0 and F1. But I know from other posts here that an F1 on the GE may be due to a touch pad rather than a bad ERC. Are there other possibilites for F0 as well? Do I approach this as you would an F1, or is there another troubleshooting approach appropriate for this situation? Any recommendations would be appreciated.
You are going to think I am a parts pusher, not the case at all, what I have seen in the tech forums is both end up being replaced..  On the GE ranges it is suggested by GE to do this since whichever you replace the other one will need to be replaced also.  I would replace both.  If you decide to order one or the other and they are bought thru this site, which I have nothing to do with except help with questions when I can, I get no kickback from any parts sales,  they can be returned for a full refund less shipping both ways.   Do not see how you can loose?  ;)
Understood. Thanks so much for the quick response - and at 9:30 on a Saturday morning! Hope y'all have a great day in Texas today!
Hey, nice table of fault codes-- domo!  :dude:
Thanks Guy....;)
OK, I ordered both the ERC and the control panel kit per your recommendations; I just received the panel, but unfortunately the ERC will be later than repairclinic.com expected (sometime after 11/28). I'm aware of the concerns of replacing the ERC if the panel is what caused the problem (bad panel could ruin the new ERC). To anyone's knowledge, though, is the reverse true? If the ERC is bad, is it reasonable to be concerned that it could corrupt a new panel?
My wife would really like me to try and replace the panel now, hoping to find that it was the problem, so we'll be able to use the oven on Thanksgiving. We do have the option of cooking at my in-law's rather than having them at our house. So, would you try replacing the panel before getting the new ERC, or eat at the in-law's? (Not a trick question - they are great folks!) :D
Wait and install both at the same time.
As it has been written, so it shall be done!!
