KEBS278DBS6 Can KitchenAid oven keypad connection be fixed?
Oven Keypad KitchenAid
3 replies to this topic
#1 eappell
eappell
  • 2 posts
Posted 24 September 2011 - 11:27 AM
We have a KitchenAid Superba (KEBS278DBS6) double oven, which had the famous "Cleaning Cycle blew my fuses" issue where we put the oven into self-cleaning mode, which blew the thermal and thermostatic fuses on the oven. Thanks to help on many threads here, I was able to get the oven open, then replaced the fuses, as well as the blower. Everything "appears" to be fine now, except every time we turn on the oven, after about a minute or two it shuts off and shows error code F2 E0. From looking at the manual, it looks like that means there is a connection error between the control board and the keypad. I've tried cleaning the connection, as suggested before, but no matter what I do I always get that error now. So I figured I would replace the keypad. Unfortunately it's no longer made and can't be replaced. I've searched everywhere.
We're being told that our only choice is to dump this oven and get a new one. What I have a big problem with is, everything seems to work fine on the oven! I can't believe we're gonna have to spend $2-3k for a new oven, when the only issue is the connection between the keypad and the control board! I'm an IT guy, I undestand computer hardware, and this keypad isn't "broken", it still works fine for setting the time, setting a timer, putting in a temperature, etc.
So I'm wondering if there's ANYTHING I can do to save this oven? Seems like an unbelievable waste to toss it because of this error code. Is there any way to bypass the error? Can anything be done? Can I replace a ribbon cable or something?
Thanks so much for your help, I really appreciate it!
Eddie
  • 24,243 posts
Posted 24 September 2011 - 11:46 AM
Looks like the white one may still be available but just not in stock right now ==> Touchpad
Try contacting Bruce at Fixyourboard.com and see if he can rebuild the touchpanel for you.
#3 RegUS_PatOff
  • 30,216 posts
Posted 24 September 2011 - 11:51 AM
... we put the oven into self-cleaning mode
this white part should work, but it's $ 562
(return for any reason, less shipping)
http://www.repaircli...?R=154&N=589776
The black part may be still available somewhere, but may not be returnable
It may be a bad Touch-panel, OR the (bad?) Controller isn't "seeing" the (good?) Touch-panel.
“My Rules”:
Rule # 1) Don't ever use Self-Clean on any Oven.
Rule # 2) If you're thinking about using Self-Clean, see rule # 1.
That can wreak havoc on Electronic Controllers and Connections.
#4 eappell
eappell
  • 2 posts
Posted 25 September 2011 - 10:48 AM
Thanks guys, I'll consider my options and discuss with the wife. Nice to know I at least have options!
Thanks again - Eddie
Also tagged with one or more of these keywords: Oven, Keypad, KitchenAid
