Richard03
frigidair gallery series, madel GLTF2940
4 posts in this topic
can someone please send me the repair manuals for this washer? washer works fine but does not spin, can someone get me started in the right direction please?
Thank you.
... washer works fine but does not spin,
... Tumbles (Agitates) OK ?
any error codes ?
491_AffinityWasherManual.pdf 20 MB
link PM'd
washes fine, pumps water fine, just does not do the spin cycle. not any error codes i have seen.
Tech sheet is inside the washer. If yours doesn't have a removable front bottom panel, you'll have to get it from thru the back. Get the tech sheet and run thru the diagnostics and tests. You'll find the problem will either be the door latch or the motor control unit.
