Maytag Dryer SDG4606AWW takes too long to dry
Maytag gas dryer too long to dry
4 replies to this topic
#1 Jim_M
Jim_M
  • 3 posts
  • Flavorite Brew:Smithwicks
Posted 26 September 2011 - 09:35 PM
7 year-old gas dryer takes 3 cycles to dry clothes. The vent is clean, no clogs. I have disassembled the machine, cleaned all parts, particularly the exhaust. Motor works, drum turns, it heats immediately, blue flame. I assume that the heat must turn off during the cycle. I tested both the cycling thermostat and the hi-limit thermostat with an ohm meter. Both are fine. Now, I'm at a loss. Any help will be most welcome. Thanks! Jim
#2 RegUS_PatOff
  • 30,278 posts
Posted 27 September 2011 - 01:00 AM
If your Vents are clean, and there's good air-flow, and you tried a load with the Vent disconnected
common fail on all Gas Dryers ..
After they age, the Gas Valve Coils get weak when warm
cheap fix
http://www.repaircli...sp?R=154&N=3479
#3 Jim_M
Jim_M
  • 3 posts
Posted 27 September 2011 - 07:49 AM
Thanks. I ordered the part. Hope this resolves it. Jim
#4 Jim_M
Jim_M
  • 3 posts
Posted 03 October 2011 - 08:39 PM
Bingo! That was the problem. Thanks Sensei.
#5 RegUS_PatOff
  • 30,278 posts
Posted 03 October 2011 - 10:48 PM
:thumbsup:
Also tagged with one or more of these keywords: Maytag, gas, dryer, too long to dry
