whirlpool lgr7646DQ1 Won't heat, loose wire
7 replies to this topic
#1 adone36
adone36
  • 3 posts
Posted 28 September 2011 - 11:05 AM
I just had my washer and dryer moved to a new location. The dryer will run, but the gas will not ignite and heat. Under the front panel on the left side is a loose white wire which must have popped loose in moving. I have searched for a half hour and cannot find a spot this wire could have been connected to. If it grounds, the GFCI instantly tripps.
Anybody have an idea where this wire goes or have an available wiring diagram?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 28 September 2011 - 11:27 AM
post picture somewhere, then post the link here
    Shōgun
  • Master Samurai Tech
  • 30,392 posts
Posted 28 September 2011 - 01:53 PM
Can also attach a photo to this topic-- hit the "More Reply Options" button below the Reply box and you'll see it.
#4 adone36
adone36
  • 3 posts
Posted 29 September 2011 - 02:02 PM
http://www.hermannse...es/PICT0001.jpg
Wire is on the far left. End is a bare clip, so it could have pulled out from a plastic sleeve
#5 RegUS_PatOff
  • 33,588 posts
Posted 29 September 2011 - 02:42 PM
That may got to the Ignitor # 4
or the Flame Sensor
can you post a picture of that area
#6 adone36
adone36
  • 3 posts
Posted 29 September 2011 - 07:59 PM
http://www.hermannse...es/PICT0004.jpg
if you look at this image (and can zoom) there is a sensor or whatever further back than your parts page. It has a blue wire with sideways spade clip attached to it. I would assume there must be another terminal on this which is for my white wire with spade clip.
#7 matt1
matt1
    Ikkō-ikki
  • 37 posts
Posted 29 September 2011 - 08:30 PM
the white wire that came off,it is connected to the radiant sensor which is mounted on the left side of funnel, radiant sensor will have a blue and a white wires connected to it. if you can't find the connector at the sensor,then it must be broke off,in that case you will have to purchased new radiant sensor. missing one of these wires, either white or blue,then dryer is running without heat,and if one of these wire touch the cabinet then you will get a spark and hopefully your GFCI will trip.
Edited by matt1, 29 September 2011 - 08:34 PM.
#8 RegUS_PatOff
  • 33,588 posts
Posted 29 September 2011 - 10:34 PM
# 49 Radiant (Flame) Sensor
http://www.repaircli...sp?R=154&N=2681
