whirlpool duet m#wfw8300sw02 door latch
3 replies to this topic
#1 bmmc
bmmc
    Sōhei
  • Chief Appliantologist
  • 156 posts
Posted 27 September 2011 - 02:30 PM
f22 door lock error.attempts to lock 6 times(clicks 6 times) then throws code.door is locking as i have to unlock manually.think i have ccu problem but would like to confirm before throwing parts at it.mini manual not much help.
Edited by bmmc, 27 September 2011 - 02:32 PM.
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 27 September 2011 - 04:55 PM
Door latch contains a locking/unlocking solenoid as well as a switch to tell the control that it is locked, sound like that communication is not there in your machine
http://www.repaircli...ber=WFW8300SW02
#3 bmmc
bmmc
    Sōhei
  • 156 posts
Posted 28 September 2011 - 11:28 AM
door latch checks ok
Edited by bmmc, 29 September 2011 - 07:53 AM.
#4 kdog
    RoughShod
  • 7,474 posts
Posted 28 September 2011 - 01:20 PM
Merged with the topic you started on this yesterday - If you remove the spring from the outer door seal, you can remove the screws holding the latch and slide it out/in between the tub and the cabinet
How to fix a Whirlpool Duet Sport washer with an F22 error code
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 28 September 2011 - 04:49 AM
This error is usually accompanied by the door lock attempting (and failing) to lock (clicking) six times and then throwing the F22 error code. Grand Master kdog explains the fire drill for this one:
Door latch contains a locking/unlocking solenoid as well as a switch to tell the...
Read Full Entry →
