Kenmore 11022702100
kenmore 11022702100 Drain spin
4 replies to this topic
#1 newcelica
newcelica
  • 1 posts
  • Flavorite Brew:bluemoon
Posted 28 September 2011 - 03:01 PM
I have a kenmore 11022702100. The problem i am having with it is that water stays in the tub and will not spin. If i hold down the lid switch it will spin and drain at the same time but will not drain first and wont do it unless u rotate the control to a spin direction. I have read the other posts on this type of thing and says bad lid switch but if i push it down farther it will work. Any suggestions.
#2 kdog
    RoughShod
  • 7,428 posts
Posted 28 September 2011 - 03:18 PM
Sounds like a failing lidswitch - take a close look and see if the bracket is broken where the screws mount
http://www.repaircli...er=110.22702100
#3 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 28 September 2011 - 04:21 PM
or you could see if the bracket is broken...LOL
#4 kdog
    RoughShod
  • 7,428 posts
Posted 28 September 2011 - 05:47 PM
Oops -lysdexic fingers - Thanx for that Kurt, corrected post
#5 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
Posted 28 September 2011 - 06:59 PM
