Dishwasher GFSD551P00WW Thing in the middle still up when cycle is finished.
GE quiet
6 replies to this topic
#1 SewTara
SewTara
  • 3 posts
Posted 29 September 2011 - 12:40 PM
So sorry for all the technical lingo but I haven't been able to find what the thing is called.
Here's the problem :
When our dishwasher is all done the cycle (sometimes we use dry sometimes we don't) and we open the door and go to roll the bottom rack out it stops because the big pole thing in the middle hasn't retracted and is still up through the middle of the dishwasher (at different heights)
It's ridiculously annoying because we forget and yank the rack out and are probably doing more damage to that piece. Also it's annoying if you remember because you have to reach into the dishwasher to push it down before sliding out the drawer.
We thought maybe it was clogged up with residue or something so I've run it empty after letting a bunch of vinegar soak in it for a few hours.
Any ideas?
Tara
#2 RegUS_PatOff
  • 30,197 posts
Posted 29 September 2011 - 01:45 PM
GSFD551POOWW
can you check that model number again ?
#3 SewTara
SewTara
  • 3 posts
Posted 29 September 2011 - 02:19 PM
Why yes I can, I switched 2 letters
It's GFSD551P00WW
Sorry about that, also I think it's numerals at the end '00' and not 'OO' I think.
#4 RegUS_PatOff
  • 30,197 posts
Posted 29 September 2011 - 02:37 PM
It's GFSD551P00WW
... that's better, but I can't find much info on that Canadian model
maybe another user can ...
#5 SewTara
SewTara
  • 3 posts
Posted 29 September 2011 - 08:41 PM
Well model aside, is there a cause for that thingie to be stuck up after the cycle in any dishwasher?
Or at least what's it called and I can ask Google, he knows everything. ;)
#6 kdog
    RoughShod
  • 7,428 posts
Posted 30 September 2011 - 01:26 AM
It's an extendable tower from the top of the lower spray arm that is supposed to collapse once the motor stops, it is likely plugged up with some crud or foreign objects. Running a Cycle with some cleaner may correct that for you, if not - replace the arm
http://www.repaircli...2X10054/1263995
Dishwasher Cleaner:
http://www.repaircli...4482929/1915432
#7 Budget Appliance Repair
  • 3,996 posts
Posted 30 September 2011 - 05:40 AM
Loading is important on any of the pop-up tower models. If you load dishes to close to the rack opening where the tower pops up then it can get hung up against said items when the water stops flowing thus not letting it drop back down.
Make sure the lower rack isn't put in backwards, (I don't think you really can do this and still close the door with the GE models but some dishwashers the lower rack will go in backwards and still be able to close the door).
Edited by Budget Appliance Repair, 30 September 2011 - 05:40 AM.
William Burk (Willie)
Eureka, CA 95501
Also tagged with one or more of these keywords: GE, quiet
