Cold water trickeling and Normal setting issues - Whrlpl LSC8244BQ0
2 replies to this topic
#1 janebench
janebench
  • 1 posts
Posted 29 September 2011 - 11:09 PM
I'm having two problems -
1 - cold water trickles out in all settings (i.e. normal, permanent press, etc) - it also leaks out where hose meets washer.
2 - In the normal setting only, the washer will stop between the rinse and spin. When I manually move it to spin, it will effectively spin and complete the process.
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 30 September 2011 - 12:47 AM
http://www.repaircli...mber=LSC8244BQ0
http://www.repaircli...5516562/1012448
    Shōgun
  • Master Samurai Tech
  • 31,202 posts
Posted 30 September 2011 - 06:34 AM
The cold water side of the water inlet valve is clogged with gunkus and possibly even gookus, though this is somewhat academic distinction in this situation. And since rinse is done with cold water and the cold water flow is restricted, the washer is stalling in rinse because it's waiting for the washer to fill with cold water.
If you're using the black rubber fill hoses, you best upgrade them to steel-braided ones to prevent a flood from a burst hose.
Grand Master kdog linked you to the correct parts. :thumbsup:
