Kenmore HE2 Plus, mod# 110.47511701. Won't agitate or spin
#1
Posted 29 September 2011 - 11:42 PM
If it's a bad MUC would the motor still turn the drum a few revolutions?
Did Ohm check on motor harness. 3 pins read 5.6 Ohmsis that a problem? should they be reading 6?
Everything else works but motor doesn't turn drum.
#2
Posted 30 September 2011 - 01:06 AM
Measure pins 4 to 5 and look for 115 - 120 ohms that will be the tach coil from motor. If that's OK check the harness wires from there to motor control.
Listening to my Furnace cycle, I too, wish I was in Belize
#3
Posted 30 September 2011 - 01:13 AM
And it's very comfortable here about 84 with a good breeze off the ocean.
#4
Posted 30 September 2011 - 01:35 AM
#5
Posted 30 September 2011 - 05:24 AM
Phase windings you are looking for 6 ohms, the tacho coil is going to be 115 - 120 ohms so if you had you meter on a continuity check that usually only reads up to around 45 - 60 ohms, need to step up to a 200 ohm or higher setting or auto range on your meter.
Eureka, CA 95501
#6
Posted 30 September 2011 - 10:02 AM
#7
Posted 30 September 2011 - 12:22 PM
Maytag / Whirlpool W10140581
may be used in models:
WFW8400T series
WFW8500T series
#8
Posted 30 September 2011 - 07:40 PM
How to test the motor in a Whirlpool Duet Sport - Kenmore HE2 Plus front load washer
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 30 September 2011 - 06:06 AMWhen...
Read Full Entry →
