nothing operates on my frigidaire FSE447GHS0 electric dryer
#1
Posted 30 September 2011 - 04:13 PM
I just bought this nice little dryer for $100, and moved it in my subaru over a 20 mile distance ( some bumps). When I plugged it in with our hooking up the vent,it worked fine for 6 loads . I then proceeded to hook up the vent , a head stack of 8 feet with an in-side the house vynol butterfly valve point in the right direction. But there is also a vallve on the outside of the house. anyhow I turned on the dryer and it worked for 5 to 10 minutes. and the top was hot to the touch. I then noticed it stopped and the cloth were dry. At this point I tried to start the dryer with no luck. completly dead.
1. the dryer light is on
2. i disconnected the high limit switch( I believe- the one that is on the rear housing the heater elements) and nothing
2.1 i shorted the leads and nothing
3. tryed to run the cycle with no heat just fluffing - nothing
the dryer will not start do anything after what I assume was running to hot and overheating.
What is a poor man to do, so i am looking for some guidance and help?
John
#2
Posted 30 September 2011 - 05:21 PM
Allahu Akbar!
#3
Posted 30 September 2011 - 06:49 PM
"May the hinges of our friendship never grow rusty"
-old Irish saying
Buy me a Beer: http://web.me.com/ze...man18007260692/
#4
Posted 30 September 2011 - 08:01 PM
#5
Posted 30 September 2011 - 09:13 PM
... in-side the house vynol butterfly valve point in the right direction.
... But there is also a vallve on the outside of the house.
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
Thermal Limiter # 36 (upper right corner)
(Thermal Fuse)
http://www.repaircli...R=154&N=1489053
#6
Posted 01 October 2011 - 08:28 AM
Now I am looking at my wiring diagram.
is the 'High Limit Thermostat' the same as the 'Thermal fuse' and is this located on the housing for the heating elements?
I tried to use a light tester and get no current going through the 'High Limit Thermostat' with aorange/black line and black lines going to it.
I tested the 'Thermal Limiter' it has two white wires , this devise showed current going through it with my light tester.
Which part should I be replacing ( it is obvious to me - but want to make sure I am referring to the corect name). Where can I get a replacement, can I get this at a lowes store ?
John
#7
Posted 01 October 2011 - 08:43 AM
just looked at the diagram and the thermal fuse part #36 seems ok but part #34 doesn't seem to pass my light tester? soam I right to say I should replace Part 36 and can someone let me know the name of it?
thanks
#8
Posted 01 October 2011 - 09:08 AM
#9
Posted 01 October 2011 - 10:00 AM
#10
Posted 01 October 2011 - 10:14 AM
-old Irish saying
#11
Posted 01 October 2011 - 10:41 AM
#12
Posted 01 October 2011 - 05:30 PM
1. measured 125 voltage across the two termianls at the plug
2. measured 250V and 125V across the connectors on the terminal BLOCK inside the dryer
3. With door closed and on high heat and turning the start knob to on position - the unit does NOT start or tumble
4. Checked continuity across the thermal fuse and it has continuity, and the voltage measured 125V across the two terminals
5. checked for continuity across the high limit Thermostat shows open or infinit resistance.
so if the part I have to replace is the 'high limit Thermostat' then when I do the following :
1. remove the leads going into th 'high limit Thermostat' and connect them together , therefore removing the 'high limit Thermostat' from the equation or ricking the syem to think I have replaced the 'high limit Thermostat'
2. I would expect the dryer to work, but alas it does not
what can I check next guys....
thanks for all your help
Also tagged with one or more of these keywords: repair, overheating
