Jenn-Air Dual Fuel Range JDS8850BDB keypad problem
13 replies to this topic
#1 barley
barley
  • 16 posts
  • Flavorite Brew:Otter Creek Copper Ale (summer) Stovepipe porter (winter)
Posted 01 October 2011 - 06:29 AM
Hoping someone can help. Numbers 1-6 on the number pad on the stove are not working. I turned off the power to the unit for more than 30 seconds hoping that it would reset itself but it didn't. When I turned the power back on there were two codes on the display: EE-214 and M-214. Any ideas? Thanks a lot!
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,959 posts
  • Flavorite Brew:Killians Red
Posted 01 October 2011 - 07:33 AM
More then likely a failed touchpad console...very common on these units...
Those numbers are just software id #'s.
#3 barley
barley
  • 16 posts
Posted 01 October 2011 - 08:06 AM
Thanks, but what's the fix? whole new console? Looks to be around $200, could probably install it myself? Is there any sort of test I can do to make sure that's the part I need?
Edited by barley, 01 October 2011 - 08:43 AM.
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,959 posts
Posted 01 October 2011 - 10:10 AM
Yep, that's the fix...pretty simple to change, you should be able to do it.
you could check the ribbon traces with an ohm meter if you had the matrix chart (maybe reg will hook you up with one) but in my experience this is a cut and dry diagnosis...could be the control but 95% of the time this is the touchpad.
#5 barley
barley
  • 16 posts
Posted 01 October 2011 - 10:49 AM
OK now I'm a little confused. KI you say it could be the control but is more than likely the keypad, but the only part I'm finding is the Electronic Control, at the following link: http://www.repaircli...7P23060/1551088
Does this include the keypad? Thanks guys.
Edited by Samurai Appliance Repair Man, 01 October 2011 - 01:55 PM.
replaced link to competing parts vendor with RepairClinic link
    Shōgun
  • Master Samurai Tech
  • 31,227 posts
Posted 01 October 2011 - 01:56 PM
Part links:
control board ==> http://www.repaircli...7P23060/1551088
touchpanel ==> http://www.repaircli...0206092/1482219
#7 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 October 2011 - 02:35 PM
#8 barley
barley
  • 16 posts
Posted 02 October 2011 - 08:44 AM
Thanks for the schematic there RegUS. Bear with me though as I'm a biologist so I am not trained in reading electrical schematics but I am a DIY fixer-upper so I reckon I can figure this out...with some assistance. I've got the unit apart and I believe I've found the part illustrated in your schematic but I am not reading any resistance across any of the points on the plug. Let me attempt to explain what I did so you may pick out what I am doing wrong. I've got the front of the stove removed (the bit with the keypad and openings for the stove knobs is flipped upside down where there is a flat "cord" and wide plug unplugged and revealed. I tested continuity on the metal bits on the plug end itself and am reading no continuity anywhere, even on points represented by keys that I know were working, such as keypad #5, cancel, etc.
DOes this make sense and can you tell me what I am doing wrong?
#9 RegUS_PatOff
  • 33,588 posts
Posted 02 October 2011 - 08:48 AM
Closed circuitry resistance
(defined as continuity): 2000 Max Ω
do you have your OHM meter set on a high enough scale ?
#10 barley
barley
  • 16 posts
Posted 02 October 2011 - 12:12 PM
Good question, my meter is pretty rudimentary. there really isn't much of an ohm scale on it but I do have it turned all the way up and when I touch the meter's probes together the needle shoots off the scale. I'm assuming this means the sensitivity of the meter is pretty high?
#11 Comstock_Services
Comstock_Services
  • Appliantologist
  • 462 posts
Posted 02 October 2011 - 12:36 PM
Did you try to have someone push the keys while you do the ohm test? :whistling:
#12 RegUS_PatOff
  • 33,588 posts
Posted 02 October 2011 - 12:58 PM
... my meter is pretty rudimentary.
... probes together the needle shoots off the scale. I'm assuming this means the sensitivity of the meter is pretty high?
1) model number ?
2) doesn't mean anything
#13 barley
barley
  • 16 posts
Posted 02 October 2011 - 02:39 PM
No Harbor freight around here but we've got hardware stores and auto parts stores. I suppose it's time for an upgrade. My meter doesn't have a brand name or a model # on it. I've had it for a long time. In the meantime I'm going to order a panel and hope it does the trick when it arrives. Thanks a lot for your time.
#14 RegUS_PatOff
  • 33,588 posts
Posted 02 October 2011 - 02:48 PM
.. My meter doesn't have a brand name or a model # on it.
.. post a picture somewhere ?
