Maytag electric double wall oven MEW6630DDS is only beeping and not functioning
beeps
13 replies to this topic
#1 lirachris
lirachris
  • 9 posts
Posted 01 October 2011 - 02:29 PM
My Maytag electric double wall oven is only beeping and not functioning. It started beeping and beeping on its own but stopped on its own. Now it doesn't beep unless you push a button. It won't do anything but beep if you push a button now (won't turn on the oven or oven lights or anything.) The clock is on and seems to be working. The timers don't work. I have tried cutting the power, waiting a few minutes and turning back on. Nothing.
No codes were shown that I saw. Is there a way to ask it what's wrong? A way to show a code?
Would this be the control panel? Replace the control panel behind the touchpad?
Thanks!
Chris
#2 RegUS_PatOff
  • 30,278 posts
Posted 01 October 2011 - 02:41 PM
Follow procedure below to use the quick test mode.
Entries must be made within 32 seconds of each other or the control will exit the quick test mode.
1. Press and hold CANCEL and BROIL pads for 3 seconds.
2. Once the control has entered the “Quick Test” mode, release both pads.
3. Press the AUTOSET button ..... Steps through last 5 diagnostic codes
#3 lirachris
lirachris
  • 9 posts
Posted 01 October 2011 - 04:09 PM
Comes up 1C 2C as the only code. I'll search around for that unless you can point me in a direction based on that. Thanks much for the procedure!
#4 lirachris
lirachris
  • 9 posts
Posted 01 October 2011 - 04:16 PM
I found the code - keyboard tail disconnected. But that makes sense because I removed the ribbon following someone else's troubleshooting. So I'm still at a loss as to what to try next to diagnose?
#5 RegUS_PatOff
  • 30,278 posts
Posted 01 October 2011 - 04:45 PM
3. Press each of the following pads indicated in the table below.
NOTE: First time one of following pads are pressed it will activate the response.
The second time the pad is pressed it will deactivate the response.
Display will indicate the following:
Pad Response
BAKE................................... Bake DLB and Bake relay activated
BROIL.................................. Broil DLB and Broil relay activated
KEEP WARM ...................... Bake DLB and Broil DLB activated
CONVECT BAKE ................ Convection Fan on high speed
CONVECT ROAST ............. Cooling Fan activated
CLEAN................................. MDL relay activated
COOK & HOLD ................... Displays last diagnostic code
FAVORITE .......................... Displays EEPROM version number
TIMER ................................. Displays main code version number
CLOCK................................ All display segments illuminated
OVEN LIGHT.......................Oven light activated
CANCEL.............................. Exit Quick Test mode
1........................................... Even segments on
2...........................................Odd segments on
3........................................... Convection Ring activated; Convection Ring DLB activated
4........................................... Bake relay activated
5........................................... Broil relay activated
6........................................... Convection relay activated
AUTOSET button ................. Steps through last 5 diagnostic codes
Edited by RegUS_PatOff, 01 October 2011 - 05:51 PM.
added AUTOSET button
#6 lirachris
lirachris
  • 9 posts
Posted 01 October 2011 - 05:32 PM
So they all seem to work except the 4 and 5 buttons which simply double beeped. After going through these twice the pad will not go into test mode and simply beeps when touching any button except cancel. For some reason the cancel button does not beep.
#7 RegUS_PatOff
  • 30,278 posts
Posted 01 October 2011 - 05:49 PM
#8 lirachris
lirachris
  • 9 posts
Posted 02 October 2011 - 08:11 AM
so are you suggesting I check continuity on all the touchpad buttons? one at time? Would this basically tell me if the touchpad is the issue? Why would 4 and 5 double-beep? Would that indicate the control panel? If I kill the power then I can go back into test mode again.
#9 lirachris
lirachris
  • 9 posts
Posted 02 October 2011 - 08:38 AM
I went through the tests again and it appears there is something not working right - the cooling fan. When I hit convection bake during test mode nothing happens. all the other functions seem to work: the oven heats up, broiler heats up, lights work, the convection fan runs, cleaning lock activates, all but the cooling fan. Might the whole pan not work due to the cooling fan? is there a way I can test that?
#10 lirachris
lirachris
  • 9 posts
Posted 02 October 2011 - 09:02 AM
so it appears the test buttons above are not exactly right. For my oven the convection roast button runs the convection fan in test mode. But when I hit 6 on the keypad the cooling fan kicks off. So the cooling fan is working. Seems like everything is working! Except I can't use my oven! Ideas?
#11 Comstock_Services
Comstock_Services
  • 462 posts
Posted 02 October 2011 - 12:51 PM
Try testing the buttons, one at a time, with the continutiy test, this will tell you if the issue is in the touchpad or in the control. if the touch pad passes then you have a bad control.
#12 lirachris
lirachris
  • 9 posts
Posted 02 October 2011 - 05:58 PM
so I tested a couple of buttons. One was totally fine at 5000 omhs. The cancel however was around 140k omhs. That's way out of spec. Would that mean that I should replace the touch pad?
#13 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 02 October 2011 - 07:56 PM
By the specs listed above yes that would indicate a bad touchpad.
control panel link
http://www.repaircli...5M43860/1543968
www.eliteapplianceservice.org
#14 lirachris
lirachris
  • 9 posts
Posted 17 October 2011 - 05:55 PM
After checking some more buttons I found that some were shooting up to 0 Ohms. So I replaced the touch panel. It worked! Yeah! Thanks so much to everyone above for all the info and advice.
