GE DSS25KSRD Refrig filter change light not working?
3 replies to this topic
#1 drgerry
drgerry
  • 6 posts
  • Flavorite Brew:coffee
Posted 02 October 2011 - 08:22 AM
GE DSS25KSRD-SS
Purchased a used refrig in January, 2011. Changed the water filter when bought.
Is the water filter indicator light supposed to be on all the time? It has never been on. I don't know how often I should change the filter but the water flow is getting very weak.
I pressed the "filter indicator" button and held it for 3 seconds and the light flashes red and then holds red and then goes out. It only does this while I'm holding the button.
What does this mean? Circuit board?
#2 Comstock_Services
Comstock_Services
  • 462 posts
Posted 02 October 2011 - 09:38 AM
you should change the filter every 3-6 months, in my experience when the water flow to the door is getting slowed down, this can be resolved by replacing the filter. You should be able to reset the filter light by holding the filter status button untill, the light holds a color, then press it again and it should change colors, and go off, then when you go to get water it should be green instead of red. SO what I'm saying is that you have to manually reset the light. Doesn't sound like a board issue to me yet.
Edited by Comstock_Services, 02 October 2011 - 09:39 AM.
#3 drgerry
drgerry
  • 6 posts
Posted 04 October 2011 - 07:30 AM
thank you, but light will not "reset". The light blinks 6 times (red), then stays on for 1-2 secs, then goes out. Will not change colors, will not come on when getting water.
I know it's not a critical issue, but we may be selling it and I would like for it to be working properly so I can get the most value out of it.
    Shōgun
  • Master Samurai Tech
  • 30,042 posts
Posted 04 October 2011 - 07:51 AM
I have had this problem on two units now. The solution in both cases was to replace the user interface and display panel.
Part link ==> http://www.repaircli...5X10423/1092914
