Kenmore Gas Dryer 110.73942101 won't heat
#1
Posted 03 October 2011 - 04:54 PM
The dryer motor runs, drum turns, blows strong from the back of the dryer but the heat does not come on (at all).
I have not started unscrewing stuff and decided i would do some online research first. Any help would be appreciated. I have a sick 5 year old that has the flu right now and we NEED laundry...
Thanks in advance for any help and/or assistance.
#2
Posted 03 October 2011 - 05:16 PM
Doesn't heat at all ?
How's the white Thermal Fuse # 59 on the Blower Assembly ?
http://www.repaircli...sp?R=154&N=2923
#3
Posted 04 October 2011 - 11:26 AM
fuse looks fine. It isn't discolored or broken - but I'm not sure what this fuse looks like burnt out. It looks ok though. Should I upload a photo?
duh just saw the video. I will check continuity.
#4
Posted 04 October 2011 - 11:35 AM
#5
Posted 04 October 2011 - 12:59 PM
you could try swapping the Motor Relay and the Heater Relay
(make notes where the wires go)
If when swapped, if the (now) Motor Relay doesn't work, you know it's bad
OR ... with the Dryer running a normal "heat" cycle,
Test for 120v AC from each side of white Thermal Fuse to chassis (ground) with the Dryer Door open
#6
Posted 05 October 2011 - 10:33 PM
Thanks in advance.
#7
Posted 05 October 2011 - 10:37 PM
# 37 and # 42
inside Control Panel
- Douglasazo likes this
#8
Posted 05 October 2011 - 11:19 PM
#9
Posted 05 October 2011 - 11:24 PM
Le Chien Rouge
#10
Posted 05 October 2011 - 11:28 PM
Weird thing but i don't think it is relevant. When I switched the relays, the interior light flickered and then did not come back on. Are the relays the same? should I switch them back?
#11
Posted 05 October 2011 - 11:34 PM
If it makes a snap and ignitor does not glow, order this:
http://www.repaircli...Kit/279311/3415
(instructional video included)
If it does not make a snap, test this thermostat on the side of the heat tube
http://www.repaircli...er=110.73942101
If that thermostat has continuity, order this:
http://www.repaircli...Set/279834/3479
The relays are the same, the bulb in the drum is likely loose
- Samurai Appliance Repair Man and Douglasazo like this
Le Chien Rouge
#12
Posted 06 October 2011 - 12:01 AM
1) Doesn't make a snap.
2) High temp thermostat has continuity
3) I should order the last part but where does it go? I want to order it.
Thanks again.
I should specify... 1st and 3rd are links to the large photos and not to the main page to order.
#13
Posted 06 October 2011 - 12:07 AM
So the only one that has a video is the second link but here is what I got.
Oops - sorry, fixed links. are you able to test for voltage (120) at plug to burner ?
And/or measure resistance of ignitor ?
Le Chien Rouge
#14
Posted 06 October 2011 - 12:10 AM
Any ideas? or just order the solenoids?
#15
Posted 06 October 2011 - 12:15 AM
Le Chien Rouge
#16
Posted 06 October 2011 - 12:30 AM
Thanks again for all your help.
#17
Posted 06 October 2011 - 12:32 AM
http://fixitnow.com/...in-a-gas-dryer/
Le Chien Rouge
#18
Posted 06 October 2011 - 12:35 AM
Le Chien Rouge
#19
Posted 06 October 2011 - 12:43 AM
#20
Posted 06 October 2011 - 12:48 AM
since your unit is not making that first click, I would want to check to verify power is getting to the burner
You could do some poking around and make sure the harness connector is pushed completely into the motor
Le Chien Rouge
Also tagged with one or more of these keywords: No heat, Kenmore, Gas, Dryer, 110.73942101
