Kenmore Gas Dryer 110.73942101 won't heat
No heat Kenmore Gas Dryer 110.73942101
26 replies to this topic
#21 kdog
    RoughShod
  • 7,428 posts
Posted 06 October 2011 - 04:32 PM
Point of interest: for some reason, this is listed in available parts for this unit (usually hard to find)
http://www.repaircli...er=110.73942101
#22 RegUS_PatOff
  • 30,278 posts
Posted 06 October 2011 - 06:02 PM
usually, if the Gas Valve Coil Solenoids are bad, you;d get heat for the part of the Drying cycle.
#23 Douglasazo
Douglasazo
    Ikkō-ikki
  • 21 posts
  • Flavorite Brew:Strange Brew
Posted 06 October 2011 - 11:07 PM
New multimeter in hand...we may be past this but here we go
OR ... with the Dryer running a normal "heat" cycle,
Test for 120v AC from each side of white Thermal Fuse to chassis (ground) with the Dryer Door open
Both sides test 120v AC
Always better to be safe than sorry - more info: http://fixitnow.com/...r-with-no-heat/
http://fixitnow.com/...in-a-gas-dryer/
I love my new toy, errrr, tool BTW, I tested the resistance of the solenoids and they appear to be functioning correctly. I have reinstalled them. Where should I test for the burner and ignitor?
#24 Douglasazo
Douglasazo
    Ikkō-ikki
  • 21 posts
Posted 06 October 2011 - 11:17 PM
If it makes a snap and ignitor does not glow, order this: 00630534.jpg (instructional video included)
If it does not make a snap, test this thermostat on the side of the heat tube
If that thermostat has continuity, order this: 00928758.jpg
The relays are the same, the bulb in the drum is likely loose
Tested the Ignitor for continuity...nothing. Pulled it out (why do they gotta screw with people and change it to 5/16, everything else is 1/4) and it looks like there is a crack and a burn mark.
This looks like the broken part...is there anything else that goes out at the same time and is typically replaced at the same time or should i be good to go?
Thanks so much guys.
#25 Douglasazo
Douglasazo
    Ikkō-ikki
  • 21 posts
Posted 06 October 2011 - 11:36 PM
Ignitor is definitely broken. Just to be thorough, there was no snap.
#26 kdog
    RoughShod
  • 7,428 posts
Posted 07 October 2011 - 12:37 AM
yep sounds good - you can check for 120v going to the ignitor at the plastic connector, also the main connector to burner
#27 Douglasazo
Douglasazo
    Ikkō-ikki
  • 21 posts
Posted 07 October 2011 - 11:57 PM
120v going to the ignitor and also to the burner. Part ordered. Thank you guys for your help.
Also tagged with one or more of these keywords: No heat, Kenmore, Gas, Dryer, 110.73942101
