Fuse bad. Frigidaire FWT645RHS0
3 replies to this topic
#1 rags1
rags1
  • 1 posts
Posted 04 October 2011 - 05:43 PM
Have run through checklist in the Frigidaire repair manual and found motor control board to be the problem. The motor itself tests fine. The fuse on the board, however, seems to be gone as well. The manual states that if the fuse is bad then the control board and the motor must be replaced. Is this necessary if the motor is ok?
#2 Dan Webster
Dan Webster
    Paw Paw
  • 1,327 posts
  • Flavorite Brew:Busch
Posted 04 October 2011 - 09:31 PM
Have you tried replacing the fuse? How have you confirmed the motor is fine?
Edited by applianceman18007260692, 04 October 2011 - 09:32 PM.
"May the hinges of our friendship never grow rusty"
-old Irish saying
Buy me a Beer: http://web.me.com/ze...man18007260692/
#3 Budget Appliance Repair
  • 4,878 posts
Posted 05 October 2011 - 06:38 AM
Replace the fuse and it will just blow again, because of whatever the problem is on the board.
I've never had to replace the motor on one of these when the fuse is blown. If all the ohm readings from the motor match the specs you should be OK with just replacing the motor control board, (a very common failure on these machines, hardly every see a bad motor).
William Burk (Willie)
Eureka, CA 95501
    Shōgun
  • Master Samurai Tech
  • 29,808 posts
Posted 05 October 2011 - 06:46 AM
Part link ==> Motor Control Unit
