eb9shkxvq defrost thermostat
7 replies to this topic
#1 jkilgore34
jkilgore34
    Sōhei
  • Chief Appliantologist
  • 121 posts
  • Flavorite Brew:Dogfish Head 120 minute IPA
Posted 04 October 2011 - 06:28 PM
I'm working on a fridge model eb9shkxvq. Would it hurt to put a frigidaire defrost thermostat on a whirlpool refrigerator?
    Shōgun
  • Master Samurai Tech
  • 30,708 posts
Posted 04 October 2011 - 06:32 PM
You mean this ==> Defrost Thermostat?
Nah, they're all made by the same company in China anyway. All that really matters is that 1) it's in roughly the same temperature operating range and 2) that it mounts on the evaporator coil correctly and reliably.
#3 jkilgore34
jkilgore34
    Sōhei
  • 121 posts
Posted 04 October 2011 - 06:35 PM
Domo sensei. I think that is how you say thank you teacher.
#4 jkilgore34
jkilgore34
    Sōhei
  • 121 posts
Posted 04 October 2011 - 06:41 PM
the thermostat I have says L47-22F. Does that mean open at 47 and above and closed at 22 and below? The tech sheet I have on the fridge says the thermistat should be open at 42 and above and closed at 12 and below. Is the thermostat I have close enough?
    Shōgun
  • 30,708 posts
Posted 04 October 2011 - 06:57 PM
It means it will open at +47F and above and will stay open until the bimetal in there feels +22F. Once closed, the contacts won't open until the bimetal feels +47F.
#6 jkilgore34
jkilgore34
    Sōhei
  • 121 posts
Posted 04 October 2011 - 07:03 PM
So you think that is close enough?
    Shōgun
  • 30,708 posts
Posted 04 October 2011 - 07:07 PM
You betcha! Probably within the precision tolerance of those cheap-azz little things anyway. :blinky:
#8 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,047 posts
Posted 05 October 2011 - 07:22 AM
Defrost bi-metals are rated just like dryer t-stat bi-metals. L47-22 means open above +47F and close at 25F, the second number is a differential just like in dryers, (IE: L155-20 surely doesn't close at 20F now does it? NO, opens at 155F and close when temp drops back down to 135F).
William Burk (Willie)
Eureka, CA 95501
