Whirlpool DU1014XTXQ1 dish hider shuts down after first cycle
silent partner i
6 replies to this topic
#1 theraymondguy
theraymondguy
  • 4 posts
  • Flavorite Brew:Hawaiin Punch
Posted 04 October 2011 - 08:02 PM
3 Month old Whirlpool Silent Partner i model DU1014XTXQ1.
Run it in any cycle or combination of heat / dry; will run for almost exactly 10 mins then shuts down:
Drain / Cancel light comes on, drains out all fluid then all lamps go dark... Clean bulb NEVER lights.
Have cycled circuit breaker, no difference (not that I expected any).
Disappointing, would rather not bring in 'The authorized service tech' without having a grasp of what might be wrong.
Thanks for your time.
Forgot to mention, heating element is not getting hot. I will now stop being stubborn and check it for continuity..
#2 theraymondguy
theraymondguy
  • 4 posts
Posted 04 October 2011 - 08:11 PM
Heating element has 13.28 Ohms resistance, thermistor reads 0.58 Ohms.
    Shōgun
  • Master Samurai Tech
  • 30,905 posts
Remove the kickplates at the bottom and get the tech sheet from the envelope pasted to the back. Put the control into diagnostic mode and run through the steps. Report. Be sure to replace the tech sheet when done.
#4 theraymondguy
theraymondguy
  • 4 posts
Posted 04 October 2011 - 08:12 PM
Pulled kick plates, did not find tech sheet.
    Shōgun
  • 30,905 posts
Posted 04 October 2011 - 08:14 PM
Look again with a flashlight. If this is a new unit only 3 months old and hasn't been serviced, it has a tech sheet.
#6 theraymondguy
theraymondguy
  • 4 posts
Posted 04 October 2011 - 08:17 PM
I have it out of the cabinet, tipped over on it's face. No tech sheet.
#7 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 04 October 2011 - 09:06 PM
... still under warranty ?
Heater could be anywhere between 8 to 30 OHMs
Thermistor should be about 50,000 OHMs @ 25C
