Magic Chef CGR3740ADH stove convert to natural gas locate orifice hoods
gas stove convert natural gas orifice hood sealed burners
6 replies to this topic
#1 skenig
skenig
  • 9 posts
Posted 05 October 2011 - 12:32 AM
Hi,
I need to convert a Magic Chef (Maytag) CGR3740ADH gas stove from LP to natural gas. The manual I have mention
1. to change the pressure regulator settings. It is easy to locate at the back of the stove and the conversion is no problem.
2. to "screw the burner orifice hoods away from the pins, approximately 1 1/2 to 2 turns".
3. to adjust the burner air shutter to the widest opening.
1 and 3 are no problem but 2 is.
I think I might be able to "screw the burner orifice hoods away from the pins, approximately 1 1/2 to 2 turns" if I knew where these "burner orifice hoods" are located. The manual does not give any hint about actual location.
The stove has sealed top burners, that I could remove with a boa wrench. I think the top "orifice hoods" maybe under the top burners, but I want to make sure before I start taking the stove apart.
I understand there is one "orifice hood" per top burner, plus one for the broiler and one for the oven burner.
Thanks!
PS: Just out of curiosity, what would happen if the regulator is set for natural gas, the stove is connected to natural gas, and the "orifice hoods" are tight against the pins? a low flame? no flame at all?
#2 RegUS_PatOff
  • 30,226 posts
Posted 05 October 2011 - 01:41 AM
#3 skenig
skenig
  • 9 posts
Posted 05 October 2011 - 09:29 AM
Thanks, RegUS, but that does not say where the orifice hoods are located, which is what I am trying to find.
#4 RegUS_PatOff
  • 30,226 posts
Posted 05 October 2011 - 10:07 AM
on each Burner .. that's where the Gas comes out
Oven Orifice shown:
  • 24,258 posts
Posted 05 October 2011 - 10:12 AM
The stove burner orifice hoods are located underneath the sealed burners. Behold:
You can get a closer look at them here ==> http://www.repaircli...mber=CGR3740ADH
#6 skenig
skenig
  • 9 posts
Posted 05 October 2011 - 02:39 PM
Many thanks! Once I located the orifice hoods, it was easy to untighten them , and now I have a beautiful big blue flame!
I bow to your knowledge, wise Fermented Grand Master.
#7 kdog
    RoughShod
  • 7,428 posts
Posted 05 October 2011 - 11:47 PM
Blue Flame = Green future
