Kitchen Aid KAWS677EQ0 No slow speed/high speed spin/drain
11 replies to this topic
#1 Glockerman
Glockerman
  • 4 posts
  • Flavorite Brew:Kostritzer
Posted 06 October 2011 - 04:35 PM
Hi, need help for kitchen aid clothes washer model #KAWS677EQ0. Fills with water, but won't go into low speed agitate. Faint humming noise for a few seconds, then none. Also won't high speed spin/drain out.
Samurai. Help me fight off the washing machine ninjas!
#2 kdog
    RoughShod
  • 7,466 posts
Posted 06 October 2011 - 04:36 PM
Sounds like you need to perform Yee Olde crap trap enema as you got a jammed pump
http://i160.photobuc.../wpdcabinet.gif
http://i160.photobuc...ers/wpwash1.jpg
http://www.repaircli...pliance-Diagram
#3 Glockerman
Glockerman
  • 4 posts
Posted 06 October 2011 - 04:53 PM
All I have to do is clean out the pump? That seems too simple a fix for no low/speed spin/drain problem.
#4 kdog
    RoughShod
  • 7,466 posts
Posted 06 October 2011 - 04:55 PM
Give it a whirl - slide the pump off of motor and see if unit will then run, not uncommon to find a sock or scanties caught in there
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 5,438 posts
Posted 06 October 2011 - 05:09 PM
Seems counter-intuitive for a pump to control a spinning tub but in this design, the motor has an axle that fits into a sprocket on the pump that turns the wheel inside the pump. If the pump wheel cannot turn due to a sock etc, the motor cannot turn or turns slowly.
www.DurhamApplianceThrift.com
#6 kdog
    RoughShod
  • 7,466 posts
Posted 06 October 2011 - 05:11 PM
yup - and a common denominator for all washers is: No pumpy = No Spinny
#7 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 06 October 2011 - 06:23 PM
... won't go into low speed agitate.
... Also won't high speed spin/drain out.
... will it do a medium Agitate and medium Spin OK ?
(probbably a bad Timer)
http://www.repaircli...sp?R=154&N=1171
#8 Glockerman
Glockerman
  • 4 posts
Posted 06 October 2011 - 06:51 PM
Well, it was a sock jammed in the pump, however...
...I destroyed the pump trying to get it to slide off the shaft. Which it still has not done. This pump will not slide off period. (Yes, I removed the clips.) I'll be ordering a new pump providing I get the pieces off of the shaft, and the shaft is not bent.
#9 RegUS_PatOff
  • 33,588 posts
Posted 06 October 2011 - 07:21 PM
... This pump will not slide off period.
... maybe a little penetrating oil (soak)
3-in-1 Oil
WD-40
maybe a heat gun / hair dryer for heat ?
#10 Glockerman
Glockerman
  • 4 posts
Posted 06 October 2011 - 08:09 PM
Well, I got all the pieces of the pump off the motor shaft. Rigged everything up to run and it works. Now I just have to order a new pump. Thanks for your help.
