Whirlpool Duet GEW9200LW1, E1 error code
Whirlpool duet e1 error
6 replies to this topic
#1 rymice
rymice
  • 5 posts
  • Flavorite Brew:Ten-Fidy Imperial Porter
Posted 09 October 2011 - 07:57 AM
I have been getting constant E1 codes on my Whirlpool GEW9200LW1 dryer. I have verified the vent is clear. I checked the thermister and ohms look good. The only way the dryer will run is in the timed cycle at low heat. At medium and high heat settings the dryer will shut down after 5 min. Same situation in automatic cycle. I noticed that the dryer is extreamly hot inside after it shuts down.
What else could cause the E1 code? Any help would be appreciated.
#2 Ritz
Ritz
    Kohai
  • Chief Appliantologist
  • 435 posts
Posted 09 October 2011 - 08:58 AM
The thermistor is directly related to E1 error code. There are different resistance levels at different temperatures. I would try this thermistor test and more than likely I would replace the thermistor
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power.
➔ Check wire connections at the machine
control electronics and thermistor. See
Accessing & Removing the Electronic
Assemblies, page 7, and figure 8 for
thermistor location.
➔ If wire connections are good, remove the
two wires from the thermistor and replace
the thermistor
#3 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
  • Flavorite Brew:Killians Red
Posted 09 October 2011 - 08:59 AM
Just because the thermistor checks good @ room temp doesnt. Mean it stays within tolerance as it heats up...
replace it.
#4 rymice
rymice
  • 5 posts
Posted 10 October 2011 - 04:42 AM
Thanks for the help oh masters of Appliantology.
  • 24,348 posts
Posted 10 October 2011 - 07:14 AM
Thermistor part link ==> Thermistor
#6 rymice
rymice
  • 5 posts
Posted 16 October 2011 - 11:49 AM
I replaced the thermister and low-and-behold the dryer is working fine. Thanks again for the help.
#7 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
Posted 17 October 2011 - 07:03 AM
:rocker:
Also tagged with one or more of these keywords: Whirlpool, duet, e1, error
How to fix an E1 error code in a Whirlpool Duet GEW9200 washer
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 10 October 2011 - 07:14 AM
Chief ReliableApp guides us through:
The thermistor is directly related to E1 error code. There are different resistance levels at different temperatures. I would try this...
Read Full Entry →
