Door Handle-- GE Spacemaker JVM1653WHO1 over the range microwave.
Microwave
3 replies to this topic
#1 Roadrash
Roadrash
  • 3 posts
Posted 09 October 2011 - 12:47 PM
Last night the handle pulled right off the door! SmartSearch shows two options: the handle for $35.00, or a complete door for over $200.00! My die-lemma is: how is the door removed? Hinges/mounts are hidden. Do I have to dismount from the wall and remove the shell? Then, once I have the door on the bench, how do I disassemble it to replace the handle? There are no exterior fasteners. Is it glued together? The handle was screwed to the door face prior to door assembly.
Apparently manuals are not available.
I can still open the door and use the micro but I don"t need to hear wifey complain about her nails!
(Or I could just put on a rope pull but then it would just end up on Redneck Fixes!)
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 09 October 2011 - 02:15 PM
from the service manual:
To Remove Door Handle:
With door open:
1. Remove inner door trim.
2. Remove door handle screws.
To Remove Door:
1. Remove power, top grille and short out the Capacitor
2. Remove the 4 (2 on top & 2 on bottom) 5/16" head screws on door hinges and #2 phillips head screw on top.
3. Door will pull away from unit with the hinges attached to the door.
4. When reinstalling door reverse procedure and a to the control panel before securing door hinge screws.
#3 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,525 posts
  • Flavorite Brew:What's on tap?
Posted 10 October 2011 - 11:55 AM
I would also order the choke cover, Item 11 in the above diagram. It breaks more often than not when prying it off to access the handle...
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#4 RegUS_PatOff
  • 33,588 posts
Posted 10 October 2011 - 02:27 PM
http://www.repaircli...?R=154&N=943106
How to replace the door handle on a GE Spacemaker JVM over-the-range microwave
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 10 October 2011 - 09:58 AM
So, you go to open the door on your GE Spacesaver microwave and the handle comes right off in your hand! What's a brutha to do? Well, bro, you have two choices: replace just the door handle or replace the entire door. Replacing the door is obvious and easy but costs six times more than replacing just the handle. And while the handle alone is a...
Read Full Entry →
