Kenmore 800 (110.298222801)
agitation fills while agitating wet clothes after spin
11 replies to this topic
#1 dskalish
dskalish
  • 5 posts
  • Flavorite Brew:Pabst Blue Ribbon
Posted 10 October 2011 - 11:34 AM
Greetings.. This kenmore is less than two years old. We never really thought it worked right from the start, (clothes at times wet after spin) The latest issue is the instant agitation while washer begins it's fill at a start of a wash. Though it will go through the wash cycle - after final spin, for about 10 seconds, water is dumped on the spun clothes. So they are left wet after the cycle ends. I then use the spin cycle on the "Hand wash" mode to fully spin the water out of the clothes. It is only in this cycle that water isn't dumped on the clothes.
After enough research, it looks to be the auto load sensing switch
http://www.repaircli...umber=W10177795
With a superceeded part number of W10292584, my guess is this is a modification of a problematic device.
I am going to give that a try, but your sage thoughts on this is appreciated. I am aware also of the hose that goes back to the control circutry. A bit of explanation on how that works, is also helpful.
#2 Comstock_Services
Comstock_Services
  • Appliantologist
  • 462 posts
Posted 10 October 2011 - 12:10 PM
ok the hose is there because the water level switch is built into the main board, that is what tells the machine that is is at the desired water level, and to start washing. yes the redesign on the load sensing switch is because it is a problimatic part.
#3 dskalish
dskalish
  • 5 posts
Posted 10 October 2011 - 01:07 PM
Thanks Bro. I will post the outcome to this.
#4 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 11 October 2011 - 06:24 PM
you can futher test by removing the 2 connectors from the load sensing switch
and turn the machine on in the fill or wash cycle....no agitation = bad load sensing switch.
If the machine still immediately agitates with the wires disconnected from the load sensing
switch the you have a bad timer....also another problematic part with this washer.
If your feeling really lucky..I've had 2 cases when both parts are bad.....
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 October 2011 - 07:39 PM
... agitation while washer begins it's fill
... it looks to be the auto load sensing switch
... a problematic device.
YES to all of the above
#6 dskalish
dskalish
  • 5 posts
Posted 11 October 2011 - 11:56 PM
I picked up the new autoload sensing switch.. turns out that the part number W10292584 is not correct for this model. It is a smaller unit with a two position switch. The one needed is W10248240, which is the larger unit as part of the water temperature switch. Oddly, after reinstalling the switch, the washer ran through it's cycles normally. I will take this one back in the hopes I can exchange for the correct item. I did all the internet searches to confirm this part number, using the model number as the search term.. Should have actually taken it out in the first place to look at it.
#7 RegUS_PatOff
  • 33,588 posts
Posted 12 October 2011 - 12:23 AM
... turns out that the part number W10292584 is not correct for this model.
too many numbers in your model number
#8 dskalish
dskalish
  • 5 posts
Posted 12 October 2011 - 12:32 AM
Indeed... one too many "twos".. just a typo here. should be 110.29822801
#9 RegUS_PatOff
  • 33,588 posts
Posted 12 October 2011 - 12:43 AM
RepairClinic lists part number W10248240 for your model number
Water Level & temperature Controller
http://www.repaircli...R=154&N=1549115
    Shōgun
  • Master Samurai Tech
  • 30,396 posts
Posted 12 October 2011 - 05:32 AM
If you buy your parts thru the parts links on this site, such as the one Grand Master Reg posted above, you can return any part for any reason for a refund for 365 days, whether it was installed or not!
#11 dskalish
dskalish
  • 5 posts
Posted 12 October 2011 - 08:48 AM
Nice!. That's the one. I will do that. Thank you. Incidently, the washer ran through two loads on the old part, so this clearly is an intermittant, or I wonder about some pressure that might have built up in the hose..I hadn't checked it on the lower end of the washer.
#12 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 12 October 2011 - 05:18 PM
no harm in checking the hose...blow through it hard. You still need to get the new switch.
How to test the auto load sensing switch in a Whirlpool/Kenmore 800 top loading washer
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 11 October 2011 - 07:45 PM
If you have the misfortune of owning one of these machines that takes away your ability to control water level (because supposedly it figures it out for you) then you need to know that you're not in Kansas...
Read Full Entry →
