Frigidaire Affinity ATF8000FG - E41, Door Locked WTD?
affinity e41 washer front loader
4 replies to this topic
#1 ladymeag
ladymeag
  • 2 posts
  • Flavorite Brew:?
Posted 10 October 2011 - 04:13 PM
I have a Frigidaire Affinity front-loading washing machine. It ran a full cycle and the contents (a blanket and mattress protector) were still soaked, so I rearranged them a bit and put them back in the machine and set it to a "spin only" cycle.
After I pushed the start button, it locked the door and lightly buzzed like it normally does and then threw up "PAU" on the display. I tried unplugging the machine, unplugging the machine for several minutes, and a few other things. When I press the start and cancel buttons simultaneously, it says E41, which I'm given to understand means the washer thinks the door is open.
I'm dead broke and need my kid's blanket - what can I do?
#2 ladymeag
ladymeag
  • 2 posts
  • Flavorite Brew:?
Posted 10 October 2011 - 04:26 PM
Alright, so I went in and pushed against the shut door with my knee and held it there, tightly for the entire spin cycle. It worked. How likely is it that I simply had too many (two) larger items in the machine and it really wash pushing on the door or is it more likely that I have a faulty door lock?
  • 24,356 posts
Posted 10 October 2011 - 05:07 PM
E41 = bad door switch. Common problem; easy, inexpensive fix. Come git you one...
Part link ==> Door Switch Assembly
#4 kdog
    RoughShod
  • 7,428 posts
Posted 10 October 2011 - 05:09 PM
make sure the door hook isn't broken (close up below) - if it's OK, you be needin' a new latch
http://www.repaircli...mber=ATF8000FG1
  • 24,356 posts
Posted 10 October 2011 - 05:12 PM
Good call, kdog! :thumbsup:
Also tagged with one or more of these keywords: affinity, e41, washer, front loader
