LG Model: WM2487HRM OE Error Message
OE
13 replies to this topic
#1 voorheisb
voorheisb
  • 6 posts
  • Flavorite Brew:Guinness
Posted 12 October 2011 - 08:41 AM
Hello All:
I have gotten a OE error occasionally. I drain the tub with the hose, cleaned the basket and then all is well for a while. This started happening more frequently recently. Sometimes the drain hose is blocked with what appears to be sand. Now, we received the OE error, I try to drain using the hose but nothing is coming out even though there is a lot of water in the tub. The tube seems to be clear as it doesn't feel solid like it did when it was blocked with sand. When I reach my fingers into the drain housing, it feels like something (resembles wet toilet paper) is blocking the left impeller.
Please let me know if you need further information. Any help would be greatly appreciated as my wife is going to kill me soon.
Brian
    Shōgun
  • Master Samurai Tech
  • 30,522 posts
Posted 12 October 2011 - 09:14 AM
Is it, in fact sand? What have you been washing? Reason I ask is that if you have gotten lots of sand or grit in washer's plumbing (such as from washing gritty beach towels that haven't been shaken out before throwing them in the washer) you probably ruined the drain pump. You should go ahead and replace the drain hose, too because you risk ruining the new pump from the residual sand left in the drain hose.
Here's the drain pump part link ==> Drain Pump
This video shows how to replace it:
And here's the drain hose part link ==> Drain Hose
And here's how to replace it:
#3 Comstock_Services
Comstock_Services
  • Appliantologist
  • 462 posts
Posted 12 October 2011 - 09:15 AM
could it be a color sheet, could it be one of those fancy all in one laundry sheets? Posted Image
#4 voorheisb
voorheisb
  • 6 posts
Posted 12 October 2011 - 09:28 AM
Thank you both for the quick reply.
To Samurai Appliance Repair Man:
I'm not really sure what it is as my wife does the laundry. It has the consistency of wet sand. We have twin 3-year-old daughters and a 14 year old son who plays football so I'm sure there have been some really dirty loads of laundry. In doing some reading, someone else commented that if I'm seeing what appears to be paper in the drain hose, that our septic tank may be full and backing up since the washing machine is at the lowest point being in the basement...gross!
One other thing: the way our builders put in the drain hook-up, it is a good 5 feet up from the bottom of the washing machine. It has worked for years but I'm wondering if this is causing problems too. Your thoughts?
To Comstock_Services:
We don't use anything in the machine other than HE liguid detergent, liquid bleach, and liquid softener that goes in the drawer up top.
    Shōgun
  • 30,522 posts
Posted 12 October 2011 - 09:30 AM
Now's a good time to ask. :argue:
It has the consistency of wet sand. .... a 14 year old son who plays football so I'm sure there have been some really dirty loads of laundry.
I rest my case. :argh:
#6 voorheisb
voorheisb
  • 6 posts
Posted 12 October 2011 - 09:51 AM
Understood. Do you think it's worth trying to clean it to see if it is just blocked or should I just replace it?
Do you really like to be paid with beer? :no:
    Shōgun
  • 30,522 posts
Posted 12 October 2011 - 09:59 AM
If it were my washer loaded with sand and grit, and I were going to trouble of replacing the pump, I'd spend the extra shekel to replace the drain hose; it's almost no extra work and avoids a potential ruined new pump down the road. I like to consolidate my efforts and save time 'cuz no one pays me to fix my own appliances -- but I'm nutty thata way. :silly:
Mmm, BEER! :gulp: :beermug: :pint1:
#8 john63
john63
    Dean of LG Appliantology
  • 2,212 posts
Posted 12 October 2011 - 10:14 AM
<<<Sometimes the drain hose is blocked with what appears to be sand>>>
The small *black* hose next to the Pump Strainer---or the large *gray* hose behind the washer?
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#9 john63
john63
  • 2,212 posts
Posted 12 October 2011 - 10:18 AM
<<<One other thing: the way our builders put in the drain hook-up, it is a good 5 feet up from the bottom of the washing machine. It has worked for years but I'm wondering if this is causing problems too. Your thoughts?>>>
The drain hose can be elevated up to 8 feet.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#10 voorheisb
voorheisb
  • 6 posts
Posted 12 October 2011 - 10:23 AM
Hi John63. The hose to which I'm referring is the small black hose next to the strainer.
#11 voorheisb
voorheisb
  • 6 posts
Posted 12 October 2011 - 10:26 AM
I was actually referring to the pump. Could it be that the pump is fine and the impeller is just blocked and can be cleaned rather than replaced? Is there a way to test the pump with a multimeter or something to see if it is good/bad?
If the pump is bad and I do need to replace it, I'll definitely replace the grey hose too as you suggested.
#12 john63
john63
  • 2,212 posts
Posted 12 October 2011 - 10:29 AM
Not uncommon for this very small diameter hose be plugged with debris.
When using this hose to drain water from the tub---avoid fully extending the hose from the washer---as this will cause a "kink" in the hose where it is attached to the pump body. Water won't drain out.
Push the hose back into the washer about 2 inches---this will allow water to drain.
If sand or other debris is blocking the tube---compressed air (strong blast) usually clears the tube of blockage.
Edited by john63, 12 October 2011 - 10:47 AM.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#13 john63
john63
  • 2,212 posts
Posted 12 October 2011 - 10:34 AM
I'd replace the DRAIN MOTOR.
As these washers age---particularly those that are used heavily---the DRAIN MOTOR can become worn.
Though the impeller on the DRAIN MOTOR is "running"---it's RPM is much slower---failing to drain all of the water from the tub consistently (erratic).
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#14 voorheisb
voorheisb
  • 6 posts
Posted 12 October 2011 - 10:37 AM
Will do. Thank you very much.
Also tagged with one or more of these keywords: OE
