Does my maytag dryer de482 have a sensor bar somewhere
12 replies to this topic
#1 bonjon33
bonjon33
  • 6 posts
  • Flavorite Brew:coke
Posted 13 October 2011 - 07:42 PM
Do you know if my dryer has a sensor bar and how do I remove the front to clean out all the lint that is in there
    Shōgun
  • Master Samurai Tech
  • 30,944 posts
Posted 13 October 2011 - 08:50 PM
Yes, yours has a sensor bar. It looks like this:
This video shows how to disassemble your dryer:
#3 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 13 October 2011 - 09:03 PM
there are 2 phillips screws o the bottom of the front about 4" up
from the bottom. remove them and pull out from the bottom until it gets to knee height and the top part
should come loose (hinged to the top with clips).
remove the door switch wires.
remove the (4) 5/16 screws holding the bulkhead to the frame. pull the bulkhead off.
wallah.....thats it.
Pay close attenion when reinstalling the bulkhead...the round
felt blower housing seal that the lint screen duct goes inside of has
a tendency to fold over on the bottom side when trying to insert the duct.
if it folds over it can cause an airflow restriction.
#4 bonjon33
bonjon33
  • 6 posts
Posted 14 October 2011 - 09:51 AM
Trying to find sensor bar to clean it. Not in the back of the dryer
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 14 October 2011 - 10:08 AM
I believe it's in the front, near the Filter
#6 bonjon33
bonjon33
  • 6 posts
Posted 14 October 2011 - 10:12 AM
do you mean the lint filter do i need to take the front off to get to it
#7 RegUS_PatOff
  • 33,588 posts
Posted 14 October 2011 - 10:17 AM
yes, near the Lint Filter, should be able to see / feel it
#8 bonjon33
bonjon33
  • 6 posts
Posted 14 October 2011 - 11:04 AM
I just can't seem to find it. I see the new part has to screws with it where does it screw into the drum or maybe the plastic looking grill thing in front of the lint screen still looking
#9 certified tech group 51
  • 2,704 posts
Posted 14 October 2011 - 04:21 PM
Have you found the sensor yet??? Can you find your wire diagram, in the console.....I had a Maytag dryer last week and the model number sounds familiar...... Does the console at the dryer timer indicate a a AUTO-DRY cycle???? I looked for one on the inside of the unit I had but no sensor. Look on the wire diagram and find a cycling thermostat, it will have four wires............ one pair is for the heater element, the other pair , one wire from the t-stat goes to the timer motor but i forget where the other wire goes....................ANY way if you look at the t-stat when it calls for heat, the contacts close................ when it reaches temp. it opens, but it also closes a circuit for the timer motor to advance... timer will advance when the element is 'off' ................... Whirlpool had a system like this one.............. If you find a sensor dis regard this post. keep us posted...
#10 RegUS_PatOff
  • 33,588 posts
Posted 14 October 2011 - 05:34 PM
after another look,
the parts diagram shows the Moisture Sensor, but no reference to it in the parts list.
That model version might not have one...
A look at the wiring diagram would confirm, but can't find one for that older c.1992 model
It may use an electrical technique to sense wet clothes.
#11 bonjon33
bonjon33
  • 6 posts
Posted 14 October 2011 - 09:06 PM
Thanks not sure either will see if anyone else has a clue
#12 RegUS_PatOff
  • 33,588 posts
Posted 14 October 2011 - 09:21 PM
... A look at the wiring diagram would confirm,
#13 bonjon33
bonjon33
  • 6 posts
Posted 15 October 2011 - 02:34 PM
Can't find wiring diagram
