I just replaced my ERC Model #JRGS14GET with the alternative ERC #WB27T10327. I only have wires For G, Neu, L1, and Broiler. I do not have a wire that will go
into L1A that is located in the relay. The oven control panel is powered on but the oven function will not heat up. How should I resolve this?
Conversion to ERC #WB27T10327
#1
Posted 14 October 2011 - 04:14 PM
#2
Posted 14 October 2011 - 05:19 PM
#3
Posted 14 October 2011 - 05:32 PM
#4
Posted 15 October 2011 - 09:12 AM
#5
Posted 16 October 2011 - 05:08 AM
Edited by Budget Appliance Repair, 16 October 2011 - 05:12 AM.
Eureka, CA 95501
#6
Posted 19 October 2011 - 06:28 PM
#7
Posted 19 October 2011 - 07:34 PM
#8
Posted 20 October 2011 - 11:37 PM
#9
Posted 21 October 2011 - 12:05 AM
Can you post a close-up picture of each end of that Wire ?
Did you need to use it ?
If not needed, does either end fit onto L1A ?
If yes, you could then cut the Black Wire and the Wire going to L1,
and use one of the Wire nuts to twist all (3) ends together.
#10
Posted 21 October 2011 - 04:43 AM
Here is the image.
Image shows White wire on L1 and Black wire on Neutral, Seems backwards by standard color codes...
Mother Teresa
#11
Posted 21 October 2011 - 09:16 AM
aahhh, yes , didn't notice ..... Seems backwards by standard color codes...
#12
Posted 21 October 2011 - 11:13 AM
The conclusion they came to was to jumper the L1 wire to go to both the L1 and L1A, so I'm taking it to be my solution too. Just got to figure out how to do that.
The black wire was just a ground wire. Do you still want the picture?
Thanks for sticking with me, guys. Just a 25-year-old girl trying to figure out how to wire her oven. :o)
#13
Posted 21 October 2011 - 01:38 PM
no, ... it may not be ":big enough" to use for the L1A... The black wire was just a ground wire. Do you still want the picture?
I'll do some searching for an alternate wire / adapter
#14
Posted 23 October 2011 - 11:41 AM
OR
you would need one of these adapters:
along with:
http://www.repaircli...R=154&N=1057763
I'm not sure if the Connect sizes are correct
Also tagged with one or more of these keywords: WB27T10327, GE, wall oven, electric
