Kitchen Aid Dishwasher KUDS01DJSS0 stops mid cycle
6 replies to this topic
#1 motougo
motougo
  • 3 posts
Posted 14 October 2011 - 11:18 PM
My dishwasher seems to run fine, but then stops mid cycle. Normal LEDs are blinking in no apparent pattern. Unit won't start again until a bit of time. Switches don't appear stuck. Seems to run again after I leave door open a bit ( maybe drying out compartment from moisture?)
    Shōgun
  • Master Samurai Tech
  • 30,057 posts
Posted 15 October 2011 - 09:14 AM
Does it stop at the exact same place in the cycle (time into the cycle) every time or does it vary?
#3 motougo
motougo
  • 3 posts
Posted 15 October 2011 - 01:05 PM
It stops at different points in the cycle. Lights then flash and I can't rerun. If I leave it sit it will start to run fine. I ran diagnostic cycle and seemed to go through all steps OK. I was thinking that water or moisture is getting in and causing the problem. Is this a known issue? If so, could it be the vent is stuck closed?
#4 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,460 posts
  • Flavorite Brew:What's on tap?
Posted 16 October 2011 - 08:00 AM
It stops at different points in the cycle. Lights then flash and I can't rerun. Is this a known issue?
Condition: Dishwasher will stop in mid-cycle and will not advance. One or more of the cycle and option indicator lights on the console will start blinking.
Correction: Electroninc Control Part number, 8528172, has been modified and returned to stock. The electronic control is reacting to higher than normal line voltage (over 125 VAC) and higher than normal line signal distortion that exists in some parts of the country.
NOTE: If the voltage is normal and just a single indicator light is blinking, the cause is usually a stuck or shorted keypad on the active overly, not the control.
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
    Shōgun
  • 30,057 posts
Posted 16 October 2011 - 11:32 AM
Domo, Master Chat!
Part link to the control board ==> http://www.repaircli...tNumber=8528172
#6 motougo
motougo
  • 3 posts
Posted 16 October 2011 - 01:03 PM
Yeah, I figured that moisture might be disrupting switch functions. If this is due to vent problem, then replacing the panel would only be a temp solution. How do I check for proper operation of vent?
    Shōgun
  • 30,057 posts
Posted 16 October 2011 - 06:56 PM
Nothing about venting or moisture in the service bulletin that Master Chat posted for you. And the correction is not to replace the control panel but the control board.
