Dryer timer Kenmore gas dryer model KGYS850LQ1
Dryer timer model numbers
5 replies to this topic
#1 BillG13
BillG13
  • 2 posts
Posted 15 October 2011 - 09:49 PM
Do the letters at the end of the Kenmore timer model numbers indicate important differences? For instance, mine is model 3976570B. Can I replace it with a 3976570 or a 3976570A?
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,944 posts
Posted 15 October 2011 - 10:55 PM
3976570 is the correct part number. Ignore the letters at the end.
Scott Wolf
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 15 October 2011 - 11:32 PM
http://www.repaircli...?R=154&N=548369
#4 BillG13
BillG13
  • 2 posts
Posted 16 October 2011 - 02:48 PM
Ok, thanks. Now I'm trying to test the timer, which makes sounds like it is working. The dryer is not working and I've tested the motor and all the thermostats and fuses I could find. I get no ohms reading between the two posts for the black wires of the timer. And when I try to bypass the timer by connecting the posts with a wire and two alligator clips I trip the circuit breaker. Am I doing it wrong or have I demonstrated that the timer is bad?
#5 RegUS_PatOff
  • 33,588 posts
Posted 16 October 2011 - 06:38 PM
... when I try to bypass the timer by connecting the posts with a wire and two alligator clips I trip the circuit breaker.
... Am I doing it wrong
... or have I demonstrated that the timer is bad?
1) the (2) Black wires are the 120v power to the Timer Motor
2) yes
3) no
#6 Scottthewolf
Scottthewolf
    Senpai
  • 2,944 posts
Posted 16 October 2011 - 07:31 PM
Check your door switch for continuity with your meter. (Dryer should be unplugged or circuit breaker turned off.)
With the lever on the door switch pressed you should get continuity.
Without touching the lever you should get an open circuit.
Scott Wolf
