GE Monogram ZISS420DRJSS ice/water dispenser
dispenser GE ZISS420DRJSS
7 replies to this topic
#1 orindabill
orindabill
  • 2 posts
  • Flavorite Brew:big wave
Posted 16 October 2011 - 08:34 PM
The flapper door needs repair (probably spring or solenoid), but I do not know how to get access. The front panel is not a pull-off like on normal GE/hotpoint models. I can't figure out how to get it apart. Two images below of front of dispenser. Help! Thanks!
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 16 October 2011 - 09:06 PM
Looking at this breadown, it looks like you have to disassemble it from the inside of the door rather than the outside of the door.
http://commercial.se...05136-00001.png
Scott Wolf
#3 Comstock_Services
Comstock_Services
  • 462 posts
Posted 17 October 2011 - 04:48 PM
http://c.searspartsd...05136-00001.png
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 17 October 2011 - 05:19 PM
Must be an echo in here, I'm getting repeated.
Scott Wolf
#5 Comstock_Services
Comstock_Services
  • 462 posts
Posted 17 October 2011 - 05:52 PM
When I clicked on the link it didn't work for me so I re posted it
#6 RegUS_PatOff
  • 30,192 posts
Posted 17 October 2011 - 06:06 PM
.. link doesn't work...
wants log-in
#7 orindabill
orindabill
  • 2 posts
Posted 18 October 2011 - 01:42 AM
thanks for those who gave the sears link ... the diagram for the GE seems to be the same (found on repalr clinic). But the parts diagram does not really contain the disassembly information. It sorts of looks like backside access, but thats so hard to believe (an unforgivable design flaw) that I really would like it confirmed by someone who actually serviced such a refrigerator.
someone with experience (or an actual service manual) please speak up!
bill
#8 RegUS_PatOff
  • 30,192 posts
Posted 18 October 2011 - 03:08 AM
from the 31-9117 service manual:
Controls
The electronic controls on the dispenser are interactive.
The control panel is equipped with a proximity sensor that causes the panel to light up
as you approach the dispenser (approx. 2 inches).
Removal
1. Remove the bezel from the outside of the freezer door.
Note: On stainless steel models, the front panel must be removed.
Remove screws from top, bottom, and hinge side.
Pull out on hinge side.
2. Remove the screw from the bottom of the control panel.
Lift up and pull the bottom of the panel out.
Disconnect the connectors, and remove the control panel.
3. Remove 4 screws and the backing panel.
4. From the back side of the panel, remove the water switch and the light socket.
5. Remove 3 screws and the duct door solenoid.
